Author Topic: Float Heights (again!)  (Read 6759 times)
Offline XS850
« on: November 25, 2025, 12:38:47 PM »
Hi All, can someone supply the relevant photos from Nurse Julie’s float height set up please, they’re not appearing when I go to the relevant tips & tricks post!
Also - has anyone ever measured the fuel quantity of a correctly set up float height? I’m getting 40ml on each carb - does that sound about right for CB400F float height setting?
Many thanks - Bruce
Re: Float Heights (again!)
« Reply #1 on: November 25, 2025, 01:49:33 PM »
« Reply #2 on: November 25, 2025, 03:29:18 PM »
I found these two links handy for setting the 21 mm float height, its quite a way down on the Vintage Bike builder, likewise it links you to the second site that wil show the 400 float type.
www.vintagebikebuilder.com/cb350-400f-carb-rebuild-demonstration.html
www.vintagebikebuilder.com/setting-mikuni-float-levels.html
I bought an inexpensive poor quality float gauge, I ened up using rubber bands to hold the setting in place. Mine was about £6 the one below looks a tad better
www.ebay.co.uk/itm/205068441561
« Last Edit: November 25, 2025, 03:38:07 PM by McCabe-Thiele (Ted) »
Offline Athame57
« Reply #3 on: November 25, 2025, 03:42:54 PM »
I use a gauge like this to set float heights myself.  ;)
1978 CB400F2 named Elen.
Offline exvalvesetdabbler
« Reply #4 on: November 25, 2025, 03:50:02 PM »
Use. A Vernier caliper with depth gauge if nothing else.
« Reply #5 on: November 25, 2025, 04:52:30 PM »
IIRC Ash made one out of an early PC floppy disc case!
« Reply #6 on: November 25, 2025, 10:21:59 PM »
You can make one from an old credit card (or even a new credit card to save unwanted spending on Christmas presents 🎁) 😉
Offline XS850
« Reply #7 on: November 26, 2025, 08:57:51 AM »
Thanks Nurse Julie - exactly what I was lookin for that makes more sense to me with your description!
Also thanks to all other comments - I have a float height guage, it was just the description of what angle to have the carbs at for setting the “close” position!
Cheers - Bruce
« Reply #8 on: November 26, 2025, 02:48:40 PM »
One question looking at julies pics is are the floats the right way up?
« Reply #9 on: November 26, 2025, 04:33:24 PM »
They were probably 500 or 550 carbs that I was fettling Bryan but I just took the photos as an example of how to set the floats.
« Reply #10 on: November 26, 2025, 05:58:38 PM »
Just a query as i just rebuilt a set for Paul Whitely and i think they came out other way up so you measured to flat side
