Author Topic: Carb Synchronising with a gauge.  (Read 6666 times)
Offline scifi
  • C90, TL125,C11, 3 1/2 HP., cb250 cb360, cb400-4.
« on: December 08, 2025, 04:04:48 PM »
Hi All, I have several Hondas, including a cb400-4 that runs really well.   I recently bought a 4 gauge meter for it and can see that the inlet manifolds have removable screws to connect the pipes.   What should I adjust (at tickover..?)    It probably need no adjustment, but I just want the practice.   The only problem I see, is that the number 8 plugs ran sooty, but when I used number 7 plugs, the central electrode was a perfect colour, after a 2 x 30 mile run.   The sootyness must be a high revs jetting, but the 4 gauges won't find this out, will it..?
My CB250 however sometime fails to start on two cylinders, and is more in need of synchronising, but I can't find any removable screws on the manifolds.
Any tips for anyone that has used these gauges, will be warmly welcomed.
Re: Carb Synchronising with a gauge.
« Reply #1 on: December 08, 2025, 04:17:06 PM »
All you are doing with gsuges is evening out the 4 seperate pulses as much as you can at the tickover so you adjust the slides to give an even vacuum on each one
Offline exvalvesetdabbler
« Reply #2 on: December 08, 2025, 09:19:01 PM »
My goto phrase is if it's not broken don't b****r about with it.
To sort out the rich running, the carbs need a look first before you break out the vac guages.
Float heights,
Float valves
Emulsion tubes/ needles worn at the top
Bunged up air filter
Fuel getting passed main jet o ring
Static balance on the bench
I'm sure others will chime in with something I have missed.
Dave
« Reply #3 on: December 09, 2025, 12:28:42 PM »
Float heights,
Float valves
Dave
I agree with all points, particularly those I've highlighted.
All a synchronisation is supposed to achieve is parity of air slides on the carburettors. Importantly, it doesn't compensate for any other fault that may be present when you carry that out with vac gauges.  By extension, if a fault existed on one cylinder, then the gauge method will, inappropriately,  install a "wrong" correction onto the slides.
One of the most important influences is the ignition, particularly on the fours, as that will definitely affect the balance outcome if it's set inaccurately.
Offline Mikep328
« Reply #4 on: December 09, 2025, 02:34:36 PM »
Agree with the comments re sorting out other possible faults.  Re sync gauges - the individual gauges quite likely will not agree out of the box. IOW, you might adjust all carbs to the same setting using the gauges but the carbs may not actually be set the same.  So with a multiple gauge set, attach each gauge in turn to the same cylinder and adjust each gauge calibration so each reads the same.  THEN you can attach all four gauges to the cylinders and get accurate indication of any difference between them.
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Offline Rayzerman
« Reply #5 on: December 09, 2025, 04:06:03 PM »
Alternate method, test each gauge with a hand vacuum pump that has a gauge, note the offsets...... or,  join all 4 gauges together and use the vacuum pump (or I suppose connect to one cylinder, and note the offsets.
'72 CB350F, 2010 CBF1000FA
Offline scifi
« Reply #6 on: December 09, 2025, 04:22:16 PM »
Thanks for all the replies.  My CB250 has rubber manifolds without the access screw holes, so my gauges won't work on that machine.   For the 400-4 I am following the O ring discussion, it is much like the main jet O ring on Mikuni carbs, that I have on my Yamaha ty175 ( think that needs 4.6 x 1.6 mm.)
btw,  Our local Aero Club had an Altimeter Calibration Manometer, that could be used to test airplanes altimeters.  We just needed to connect all the pipes together with Tee Pieces.
Offline kevski
« Reply #7 on: December 11, 2025, 05:05:45 PM »
Ideally with clean and serviced carbs, running stock jetting and filters, you need to bench synchronise the butterfly's or slides first, then run the bike up to temperature  synchronise at around 4k rpm using the synchronising screws between carbs,  then on idle using the pilot circuit fuel or air screw, whichever is applicable.
But if your bike is running fine don't touch it, also don't just warm it up in the garage all the time as this will leave the plugs black and make them hard to start and miss on cylinders.
« Last Edit: December 11, 2025, 05:08:46 PM by kevski »
