Author Topic: Float bowl drain screws  (Read 15011 times)
Offline Seabeowner
Re: Float bowl drain screws
« Reply #15 on: January 01, 2026, 07:55:46 PM »
Seems unobtainable even looking fpr barbs, adapters, what have you.
You could try buying a bigger fitting and a die. But a pain.
https://www.ebay.co.uk/itm/157439372682
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline Rayzerman
« Reply #16 on: January 03, 2026, 12:40:22 AM »
My original drain screws were a bit chewed up from previous owners, so I bought a new afermarket set..... then I drilled the old ones just big enough for a plastic straw to go through for a real snug fit (in other words, I didn't use any glue or epoxy, maybe you should).... then I slipped silicone clear tubing onto them and used them as my clear tube tools.  I could not find 6x0.75 adapters either, so used what I had.
'72 CB350F, 2010 CBF1000FA
