Author Topic: rebuilding carbs  (Read 53342 times)
Offline exvalvesetdabbler
Re: rebuilding carbs
« Reply #15 on: February 12, 2026, 06:53:54 PM »
I have been distracted the last couple of days trying to get my ultrasonic bath working after 15 years sitting in the loft.  It's an old industrial one dating from the 90s that decided to start popping fuses coupled with a leaky heating element which is why it was thrown out at work many years ago.  Heater perminateley disconnected and the fault on the transducer board  now fixed.  It frequency sweeps so I didn't want to give up on it because I would never afford a new one having these specs. After 20 minutes running the water is up to 40 Deg without the heater any way.  Lots of bits to degrease now including the carb bodies before they go off for wet blasting. No doubt there will be a few watch straps and jewellery joining the queue.
In between fixing this and other jobs I had a look at the pivot pins that locate the floats, none were particularly great so I set about making some new ones.  2 mm diameter brass rod, 23mm in length and chamfered at both ends.
The two at the top are old ones.
Regards
Dave
« Reply #16 on: February 13, 2026, 02:21:47 PM »
**********TECH OVERLOAD WARNING! ALERT FOR ODDJOB, ETC.  ;D*********
I got my ultrasonic cleaner out of the skip at work and fixed it ...made by Ultrawave.
It worked great for a while then BANG ! popping all fuses. Managed to fix it but after a few months BANG ! again.
When I looked at the bank of output transistors they all had a number hand written on them. I found out that they matched all of the transistors at the factory and I don't have a clue how to do that. I don't think it's just a matter of gain matching... If you don't perfectly match them, then they don't share the current correctly and eventually go BANG! Problem is with the design of these things they are switching high voltages at high frequency into a highly capacitive load.
Ultrawave is similar design to this one.
I do have another smaller one that is of the same era and that seems less fragile. Made by Decon Scientific. Pic is of 300B model but mine is a 400B so larger. Got given it as being 'BER... (Beyond Economic Repair).
« Reply #17 on: February 13, 2026, 04:54:26 PM »
Ash , the one I have is a ex lab Decon model like the beige one in your pics , a 200w version.The QC sticker inside is dated 1990.  The problem that I found was with a triac bolted to the earthed chassis.  Someone didn't deburr the hole properly and the burr had penetrated the insulator to give an intermittent short.  Luckily I had some more insulator pads to fix it after deburring the mounting hole.  There's no real chance of getting at the heating element without de bonding the tank from the enclosure. It was electrically leaky sufficiently to fail a PAT test and that's why it was on its way to a skip before I rescued it.
It's amazing the amount of stuff that gets tossed in a skip when a lab closes or no longer needed. My boss would routinely lecture me on hoarding stuff that might come in handy one day, Apparently it costs money to store stuff you no longer need.
Regards
Dave
« Reply #18 on: February 13, 2026, 05:50:33 PM »
Regards
Dave
The Decon ones are much easier to fix apart from the bonded on heater pads. I find the Decon one heats up pretty good anyway without the heater on. The  Decon ones have a proper toroidal mains transformer but the Utrawave has just mains rectified power and  an output transformer, which drives the bobbin shaped ultrasonic transmitters and provides mains isolation . My Decon one has flat bonded on transmitters .
The modern Utrawave cleaners have a PIC micro that drives the power module and if that goes pop you are stuffed as they would never share the code and I bet the PCB costs more than the cleaner is worth. Built in obsolescence eh !
« Reply #19 on: February 13, 2026, 07:53:58 PM »
Still got my blown Ultrasonic Ash. Never got round to fixing it. If I sent you the PCB do you think you could fix it?
« Reply #20 on: February 13, 2026, 07:57:40 PM »
By all means Ken but quite often they require factory matched parts as in post. Chinese ones can be tricky and of dubious safety concerns.
« Reply #21 on: February 13, 2026, 08:07:36 PM »
May be a while before I can get to it. It's above the door in my garage and my mobility these days leaves something to be desired. As soon as I can get to it and remove the PCB I'll contact you. Thanks mate. I'm kinda low ATM and little gestures like yours mean so much when you feel the worlds against you.
« Reply #22 on: February 13, 2026, 08:14:50 PM »
Always here for you Ken ..you know that mate. Just tell me the make if you know it without venturing outside of course.
« Reply #23 on: February 21, 2026, 06:54:50 PM »
Things are warming up so been able to spend a bit of time in the garage just  catching up on a few odd jobs.
First one was to prep a handful of button socket caps ready for refitting the choke flaps.  Just drilled  the ends M2 so that they can be expanded with a center punch so they can't escape if they come loose. The primary hold down will be loctite, this gives a bit of extra security and they can be unscrewed if they ever need to come out again.
Second job was to make the brass post that the choke lever rod attaches to.  The original was removed some years ago because the  hole was quite worn and there was a lot of free play. Secondly trying to replate something that allows chemicals to get trapped us just asking for trouble later on.
I used M6 X 0.75 thread and made it so the thread bottoms out just before it gets too tight in the lever. On final assembly the threads can be staked together with a blob of loctite for good measure
Regards
Dave
« Last Edit: February 21, 2026, 07:00:48 PM by exvalvesetdabbler »
« Reply #24 on: February 22, 2026, 09:57:56 AM »
Very nice work and attention to detail.
« Reply #25 on: February 22, 2026, 03:44:14 PM »
It’s a great skill to be able just to make that missing or knackered parts. I have thought about buying a small lathe but just can’t justify the cost or the space for it. Might have to sell a bike…😳 Nope that ain’t happening.😂
« Reply #26 on: February 22, 2026, 08:04:43 PM »
You've always got Ian. 👍
« Reply #27 on: February 22, 2026, 10:03:37 PM »
Indeed Gareth! He’s already helped me out a few times. He’s a bit of a legend here. We won’t tell him though! 🤣
« Reply #28 on: February 24, 2026, 10:50:36 PM »
A lathe is the best tool you never knew you needed until you get one Johnny.
Seriously go for it if you can and you have the space. You can get a good Myford ML7 with a single phase motor for not a lot of money these days. The one I would go for would be a Super 7 with a gearbox but they are expensive. I have a ML7, I paid £500 for it about 8 years ago and it came with a stand and a suds tray.
Once you get a lathe you will wonder why you never got one before!
« Reply #29 on: February 24, 2026, 11:15:08 PM »
This is exactly the same as mine 1970s Emcomat 7 with milling head. It was made in Austria ....I think more modern ones were made in China ...I don't use it that often ( did woodwork at school  :-[ ) ... but really handy for making small parts for my bikes. I paid about £500 for it about 20 years ago.
