Author Topic: Fork stud stripped.  (Read 11886 times)
Offline Bradders
Fork stud stripped.
« on: January 09, 2026, 04:59:01 PM »
Afternoon all.  Took my front wheel off today but on replacing it one of studs seems to have a stripped thread. Was wondering how difficult it will be to replace and where’s the best place to buy them from. Regards.
Offline Ken4004
Re: Fork stud stripped.
« Reply #1 on: January 09, 2026, 05:25:16 PM »
If there is any useable thread left you can run a die down the stud to recut the thread and then use two nut locked together to remove the stud.
The fork is probably held in with some form of loctite, these loctites are extremely strong bonds until heat is applied so the best course of action is to heat the forks not the stud with a hot air gun and then you should be able to remove the stud using the two nuts locked together.
I would think a new stud should be fairly easy to acquire on line.
Offline Ken4004
« Reply #2 on: January 09, 2026, 05:35:01 PM »
Just looked on line looks like CMSNL.com have these studs with giving them a call, look like M8 studs similar to the exhaust studs just a bit of a longer thread.
Offline Bradders
« Reply #3 on: January 09, 2026, 07:02:41 PM »
Thanks for your reply Ken. It gets worse, just tried to get the nut off and it just goes round and round doing nothing! So frustrating!
« Reply #4 on: January 09, 2026, 07:13:06 PM »
Remove the other nut, put a screwdriver in the slot by the stripped one, lever the cap off whilst turning the nut, it should pick up the thread and undo
Offline Bradders
« Reply #5 on: January 09, 2026, 07:25:57 PM »
Thanks Bryan, I’ll give it a try.
« Reply #6 on: January 09, 2026, 08:12:45 PM »
If it doesnt work you will need to split the nut to get it off
Offline Bradders
« Reply #7 on: January 09, 2026, 08:56:01 PM »
Cheers Bryan. I had the hacksaw at it this afternoon but couldn’t get at it. I will try your idea tomorrow.
Offline Bradders
« Reply #8 on: January 10, 2026, 03:32:21 PM »
Bryan, your suggestion did the trick. Thanks very much.
« Reply #9 on: January 10, 2026, 08:16:36 PM »
Old school mate, all you need now is the stud out and a new one, mole grips or stillsons to remove as thread is too knackered for double nut
Offline Bradders
« Reply #10 on: January 10, 2026, 09:38:36 PM »
Thanks Bryan. I would never of thought of doing it that way. Should I be able to do the job without dismantling the forks. When I put the new one in should I lock tight it in?
« Reply #11 on: January 10, 2026, 10:52:28 PM »
No need to dismantle, personally i wouldnt locktite, you may need to take it out sometime!.
The hole is a blind hole so nothing should leak
Offline Bradders
« Reply #12 on: January 11, 2026, 08:01:46 AM »
Thanks Bryan for the info.
Offline kevski
« Reply #13 on: January 11, 2026, 08:53:38 AM »
As Bryan says, but it may already have some sort of thread lock in there so do not be surprised if it needs warming a little, when putting the new stud in apply a little threadlock on it, not arraldite or the likes of, the threadlock ensures the stud stays without being solidly glued in if you have to remove nut again.
Offline Bradders
« Reply #14 on: January 11, 2026, 06:21:08 PM »
Thanks Kevski, sounds like a plan.
