Author Topic: Lower yoke steering stops  (Read 3243 times)
Offline Grewth
« on: January 11, 2026, 07:27:25 PM »
I've got three 550/500 lower yokes with damaged steering stop lugs.
Planning to build up with weld and grind back to the original profile.
I'm just wondering what the original material is,  and what welding process would be best.
Tempted to try MIG welding with mild steel wire.
Maybe stick welding with a special rod would be better ?
Any Metalurgists out there  ?
Re: Lower yoke steering stops
« Reply #1 on: January 11, 2026, 07:58:40 PM »
Ordinary steel stick rods work ok, i think they are cast steel
« Reply #2 on: January 11, 2026, 08:08:09 PM »
I belive they are steel casting, and welding compatible without any special measure. Also welded to the central pivot, usually underneath the item.
When contemporary, a friend altered a 750 F2 example, by milling off original lugs, this to give a flat site to then weld in place significantly stronger and larger form items to make them more robust.
At the time, we were both working in engineering with metallurgy and analysis capabilities, checked through there as to material which verified the above view.
Plain stick method or decent grunt in mig etc to get competent amalgamation of weld site, else the result will just snap off easily.
If you want to build up a weld "lump" though, grind away flat, cover with lines of weld bead then clean the surface and go again on top. Repeating to height, you may need to grind top surface intermediately to get get good secure layering in building up.
Don't quench at all, just let cool between welds to avoid any crystalline risk.
We examined this process too during weld training, building up layers until sufficient to then cut the whole into cross section, ultimately to be then acid etched to expose any included faults etc.
Offline Grewth
« Reply #3 on: January 11, 2026, 09:38:13 PM »
Many thanks  !
It makes a pleasant change to get a well informed reply.
It's been a long time since I actually had to get involved with the technical side of welding,  I've just been doing a lot of fairly simple MIG fabrication.
However,  my employers have just dumped a pile of Stainless Steel fabrication and welding on me, something that I hadn't done for 30 years.
As for the yokes, I think I'm going to use the stick welder.
