Author Topic: Cb400/4 No power to points  (Read 4999 times)
Offline Coppertop1234
  • As long as the wife is happy
« on: January 17, 2026, 05:36:55 PM »
Hi all been away for a while from the forum
wow last post was 2018 time flies
but the biking bug never dies.
Just playing with a 400/4 and no power to points
Powers up and turns over fine
Checked wiring connectors all seem ok
Replaced points condenser - same issue
kill switch seems ok
possible zenner diode fault?
advice appreciated
« Last Edit: January 17, 2026, 05:50:35 PM by Coppertop1234 »
I Love Tinkering with Old Classics
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1962 Triumph 650 Bonneville
1972 Norton Commando
1978 Honda CB400/4
1976 CB750F1
1976 Suzuki GT750 Kettle
1978 Honda CB 750 F1
Married Life No Bikes for a while then
1975 CB Honda 400/4 Restoration
1976 Kawasaki Z650   Restoration
2002 Suzuki GSX1400
1976 Honda cb750F1  Restoration
1978 Honda cb750 F1 Restoration
1977 CB 250 Dream    Restoration
1977 CB400/4  - The last one - Restoration
Re: Cb400/4 No power to points
« Reply #1 on: January 17, 2026, 05:50:38 PM »
Power to coils on the black/white wire?
« Reply #2 on: January 17, 2026, 05:53:38 PM »
will check them out tomorrow cheers
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
« Reply #3 on: January 17, 2026, 06:15:04 PM »
No power to coils
New battery fitted
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
« Reply #4 on: January 17, 2026, 07:06:54 PM »
I would start by checking the voltage from the ignition switch and work my way using the wiring diagram following the ignition feed  wire all the way to the coils.
« Reply #5 on: January 17, 2026, 07:32:32 PM »
Coils are powered through the kill switch. Open the headlight and see if the switch has power and if so it's coming out of the black/white wire in the headlight. If not the switch is most likely dirty, simple to clean if it is. You could jump the kill switch by jumping a black wire into the black/white wire and see if it fires up, ignition switch on of course.
