Author Topic: Hello  (Read 3788 times)
Offline sproggy
Hello
« on: December 22, 2010, 12:25:14 PM »
Hello all. I've just signed up having bought a CB550K. Registered in '80 but I believe it's a '77 model. Looked like this when I bought it last week:
Looks like this now:
A bit more work to do (!) but with only 22k miles on the clock (10+ years in storage until a few weeks ago) it seems mechanically pretty good.... Well, it has a new MoT and I rode it home from the seller's house OK.
What's amazed me is how easily it all came apart - nothing siezed, rusted or whatever. A far cry from my '03 Transalp daily rider.
Offline florence
Re: Hello
« Reply #1 on: December 22, 2010, 07:41:50 PM »
Welcome, looks in fantastic condition.  Why are you taking it apart if it all works?
Re: Hello
« Reply #2 on: December 22, 2010, 08:35:16 PM »
Hello and welcome to the forum, looks like you've got stuck in pretty quickly.
I like doing more in depth maintenance as it's good riding it if setup properly and all the bearings etc checked out.
Offline sproggy
Re: Hello
« Reply #3 on: December 23, 2010, 09:12:40 AM »
Two reasons - first is that photos can be deceptive - it's pretty tired cosmetically, with the engine needing re-finishing, the lacquer on the tank flaking off and various other issues. Second reason is that I bought the bike as a basis for a project that will see its appearance change quite significantly, although mechanically it'll stay fairly standard.
K2-K6, in terms of bearings/suspension/brakes it seems spot on and felt surprisingly 'modern' in that respect when I rode it, however the 4000rpm idle speed when it's warm combined with a clutch that almost needs two hands to operate mean that the stop/start riding on the way home wasn't exactly a pleasure! I look forward to riding it when I've sorted it all.
Re: Hello
« Reply #4 on: December 24, 2010, 05:52:40 AM »
High tickover is almost certainly carb adjustment along with possibly blocked pilots whilst heavy clutch is cable,
Both worth sorting BEFORE you strip it down
Offline sproggy
Re: Hello
« Reply #5 on: December 24, 2010, 10:16:06 AM »
Thanks for the advice. The bike stood for over 10 years and I would guess the carbs weren't drained so there'll be all kinds of residue in them - I'm planning to get them ultrasonically cleaned. I'd replace the clutch cable as a matter of course during the rebuild.
What makes you suggest sorting these things before stripping the bike? Just to make sure they're not masking another problem?
Re: Hello
« Reply #6 on: December 25, 2010, 05:06:57 AM »
YUp, sort the known stuff, then look for more
Offline mickwinf
Re: Hello
« Reply #7 on: December 25, 2010, 01:16:11 PM »
hi Sproggy, welcome to the forum.Your bike looks to be in similar condition to my k3 which is waiting for restoration after i finish the other k3 in my garage! I have found them a fairly easy bike to work on as they are from my era, the 70s! good luck with the rebuild any advise i can give just ask,althoug there are many better qualified on this forum! cheers, Mick
