Author Topic: Rear wheel spacer dimensions  (Read 28635 times)
Offline Murf
« on: February 13, 2026, 12:09:23 AM »
Hi
Can anyone tell me the dimensions of the brake side spacer on the rear wheel, 1975 K1 550.
I am just putting the rear wheel back on and don’t seem to be able to find it, it isn’t lost as such but just seems to be evading me at the moment.  It’s the only bit I have misplaced so far during my build.
I will have another look tomorrow then will make one if I cant find it.  The length is the main thing I need, the outside diameter would be useful.
If no one has the dimensions I will be able to work them out, but it would be good to have the original dimensions to work to as then I know it is right.
Thanks.
Offline mickwinf
Re: Rear wheel spacer dimensions
« Reply #1 on: February 13, 2026, 10:29:45 AM »
It should be the same as my 500, and I have my wheel off at the moment. I can measure it for you
« Reply #2 on: February 13, 2026, 12:31:27 PM »
Max used to make them in stainless Murf. He has an eBay page nowadays and they could still be listed on there. He made one for me when he was a member on here and did a really great job of it as well, no more rust etc.
Offline Murf
« Reply #3 on: February 13, 2026, 01:36:46 PM »
Hi Mick yes I am pretty sure it will be the same as the 500 it would be good if you can measure it for me, length is the most important, it’s bobbin shaped so just the diameter at the end will be ok.
Thank
Hi Oddjob thanks for the info, fortunately I have got a lathe and just happen to have a piece of SS bar that should be long enough so will be able to make one.
However I did look on CMSNL to see if their parts diagrams had any dimensions, they didn’t but I did notice that the wheel spacer was in the region of £59 and were out of stock, so your friend could be a life and money saver for someone.
Offline DomP
« Reply #4 on: February 13, 2026, 02:44:51 PM »
I can measure my original when I get back home, currently heading for Lochgoilhead for a week.  I contacted Max last year and he made one for me.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #5 on: February 13, 2026, 07:51:19 PM »
IIRC Dom you have a 550F and Murf has a 550K, spacers are different. The 550K is essentially a 500 four with a 550 engine in it so it needs the 500 spacer dimensions.
« Reply #6 on: February 13, 2026, 07:57:00 PM »
I fitted SS rear spacers supplied by Max, he also made a batch of SS Carb shafts
If you PM me I can send his direct contact details.
Sadly left this site due to being the subject of  indirect bullying.
« Last Edit: February 14, 2026, 12:25:42 AM by McCabe-Thiele (Ted) »
Offline Murf
« Reply #7 on: February 13, 2026, 11:38:50 PM »
Thanks for all the replies and help.
I have now found the spacer, it was in with my CBX stuff. It looks like a spacer that is used on the lower rear engine mount, I sort of remember seeing it on the bench a while ago and wondering why a CBX part was out so put it on the CBX shelf.
So all good you might think, well no, I thought it would be an aluminium spacer that I could just polish up, but it is just a plated steel one that is rusty. So I am still going to make one but at least I have the original to copy now.  I am going to use aluminium which should be fine. I will post a photo.
As you say the early 550 is basically the 500 with a 550 engine, I mostly use the 500 parts manual in Ash’s drop box as a guide when assembling things, except the engine.
Thanks for all the responses
« Reply #8 on: February 14, 2026, 12:16:37 AM »
Didn't know you had a CBX as well Murf. Jealous now. Keep promising myself that if I get some money together someday and it's not earmarked for the house I'll treat myself to a red CBX. Not the prolink type though, never really liked those. Fancy a CBX550 as well.
Offline DomP
« Reply #9 on: February 14, 2026, 08:11:16 AM »
You're correct Ken!
1975 XS650B
« Reply #10 on: February 14, 2026, 10:00:22 AM »
Exactly the same thoughts over here Ken. The red CBX was (and still is) so cool. The 550F2 CBX was the same but a lot cheaper although I still couldn't afford one when they were new!
« Reply #11 on: February 14, 2026, 07:16:57 PM »
Bought a 550cbx before my heart attack then later recommisioned it and sold it for a profit for once, always hated the front brakes, you needed a degree in origami to put the front wheel in, i understand there is a good market in exporting back to Japan
Offline Murf
« Reply #12 on: February 18, 2026, 12:33:19 AM »
Hi Oddjob
Yes I am lucky enough to have a 1979 CBX Z Super sport the original twin shock type, mine is a silver one, I understand what you are saying about the candy red ones, it is a beautiful colour for a motorbike and looks great on the CBX,  I like to think of the silver ones as less common and more elegant than the red 😂. There were only the two colours although you have probably seen some black ones as well, the black was for the A model which came out slightly later and was detuned to sub 100 BHP for the German market.
I decided I wanted one and got mine as a stripped to the last nut and bolt inc the engine basket case in 2003. It’s a common tale, it had been stripped down 15 years earlier by the seller with the intention of rebuilding it which never happened.  Fortunately over the years he had been buying parts for the rebuild and these came with it. It took me about 18 months to rebuild it, I had the frame painted and did a nice job of the rebuild, it’s a beautiful thing and a nice bike to ride. Engine is smooth with plenty of torque, standard brakes are crap and suspension very 70s.
It’s lucky to have survived as another person had made an offer on it which was excepted but he then lowered his offer, this pissed the seller off, I found out it was for sale and offered the full amount.  I got to know the guy that had made the offer via the CBX community and that he just wanted it to sell as parts. He dropped a bollox by being greedy because there was some expensive new parts with it.
If you decide to get one, join a CBX club first, The CBX Enthusiasts club is very active. good bikes  at realistic prices do come up within the two CBX clubs and that’s the best place to buy one from.
« Last Edit: February 18, 2026, 12:35:08 AM by Murf »
« Reply #13 on: February 18, 2026, 01:20:05 PM »
A few photos of the beast would be nice please Murf😎👍
« Reply #14 on: February 18, 2026, 05:20:37 PM »
If I ever get to the point I’m seriously looking for one Murf I’ll do that. Done loads of work on the cbx when I was in the trade. For some reason I always seemed to get them when they came in for work. Maybe they intimidated the other mechanics? I used to have hundreds of spare shims for them but gave them away a few years ago.
I presume yours has the vacuum petrol tap mod?
