Author Topic: Yamaha CS5  (Read 56995 times)
Re: Yamaha CS5
« Reply #30 on: April 06, 2026, 09:53:47 PM »
Matchsticks dont work mate, believe me!!
Offline Yetanotherbike
  • Too many projects, not enough time
Re: Yamaha CS5
« Reply #31 on: April 06, 2026, 09:55:24 PM »
My first bike was a Yamaha RD200. As I recall the dyno starter was similar to a design Villiers patented many moons before. Starting was almost instant.
Honda CB400F2 (yellow)
Triumph Daytona 995i
Honda CBF500
180 Laverda Jota
Laverda 750 Formula S
Kawasaki 900 Z1A
Morini 3 1/2 Sport
BSA C15
MV Agusta 125 1959 (project)
Honda CB400/4 F2 (project)
Saab 900 Turbo
Saab 96v4 Rally replica
Audi 100 Coupe S
Re: Yamaha CS5
« Reply #32 on: April 06, 2026, 10:18:15 PM »
I am smarter than that
I will use a lighter!!
Re: Yamaha CS5
« Reply #33 on: April 07, 2026, 04:47:54 AM »
Not sure but I may have a homemade one of that special tool. Was it shaped like a flat letter U? You held the weights open and inserted the legs of the U into small holes in the weights?
Re: Yamaha CS5
« Reply #34 on: April 07, 2026, 06:00:49 AM »
Sort of Ken, my homemade one was made from braking rod and bent in a bit in middle of straight bits of U to give it some "springiness" mate.
Still got the Yamaha dti in box somewhere
Re: Yamaha CS5
« Reply #35 on: April 07, 2026, 07:07:48 AM »
Yes gentleman,
Thanks for your input
Offline neat street
Re: Yamaha CS5
« Reply #36 on: April 07, 2026, 07:30:58 AM »
While it is chilly,and windy I am sitting and planning ahead,
The tank has rust inside,
Looks intact, but I would like to remove/neutralise it, any advice for   doing that?
Next I have ordered a wheel  rim,so  into the unknown, having a go at wheel building, all the spokes and nipples have been loosened and  checked, will be stripping the brakes and overhauling lubricating the cams etc,
Advice welcome
Hi John, just seen this part of your post. I used white vinegar, fill tank to brim for a day or so, clean with presure washer. came out like new inside, just put some oil with diesel in the tank to stop any flash rust appearing.
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Re: Yamaha CS5
« Reply #37 on: April 07, 2026, 04:10:39 PM »
Advice welcome
Thanks, just ordered 10ltrs
I assume neat is best
No pun intended
Re: Yamaha CS5
« Reply #38 on: April 14, 2026, 11:34:24 AM »
Ok,a little bit of work over the last few days
Tank cleaned inside, Thank you Mr Street for the info,
Now a carb issue, LH is corroded, float pin stuck, need to be careful, don't want to break the pins
Advice needed,
Re: Yamaha CS5
« Reply #39 on: April 14, 2026, 11:49:31 AM »
You could try steaming it, wallpaper stripper ? If it's gummed on the pin, that can free it.
Or boil it in water in an old saucepan.
Offline Skoti
Re: Yamaha CS5
« Reply #40 on: April 14, 2026, 02:17:42 PM »
Advice needed,
I would try and gently heat the carb with a hot air gun, being careful not to loosen the soldered parts on the brass float. Maybe fashion an old beer can to direct the heat away from the float?
Your tank looks good, wish I done that with mine 10 years ago instead of the sealer which is starting to lift now.
Skoti
1976 Honda CB750F1
Re: Yamaha CS5
« Reply #41 on: April 14, 2026, 03:43:28 PM »
I think I'd try the more gentle hot water method first in an ultrasonic bath with some carb cleaner fluid added.
This could be followed by a good dose of carb cleaner on the pivot and then another hot bath. You'd have to really careful if using a naked flame with the solder on the float being so close by.
Re: Yamaha CS5
« Reply #42 on: April 14, 2026, 05:13:20 PM »
For lower risk heating I use one of Wendy's old hair driers.
Upgrades include a Bosch Paint stripping heat gun,
lastly my Plumbers Calor Gas Torch.
None of the above worked on the seized center stand pivot on my 400, I had to resort to a hack saw and impact tool.
Re: Yamaha CS5
« Reply #43 on: April 15, 2026, 10:26:30 AM »
Thanks for all the help
Another option
A Chinese copy of the carb is online at £25,
So it might be worth a punt to see how good it is,
But, no rush, a little later I shall be making carb broth,
Don't fancy the taste!!
Offline Skoti
Re: Yamaha CS5
« Reply #44 on: April 15, 2026, 11:26:38 AM »
Another option
John,
good luck with the Chinese carb, I've never had one yet that I've been able to make work properly on two stroke engines.
They're now in a box under my bench marked "junk".
Skoti
1976 Honda CB750F1
