Author Topic: Yamaha CS5  (Read 56915 times)
Re: Yamaha CS5
« Reply #60 on: May 01, 2026, 01:22:23 PM »
Interesting morning
Thought I would see what the control box did,
According to manuals,the centre unit is a cut out,
The big one on the end is the starter solenoid,
Other voltage relay
So with the engine running at fast tickover, about 1700
I pressed the voltage relay switch, nothing happened,
Then the middle one
Charge light out,
But about 4 seconds later, the main/only fuse blew
Time to ponder again
Pictures
Re: Yamaha CS5
« Reply #61 on: May 10, 2026, 12:10:54 PM »
still having charging issues,
  after a little running,the charge light does dim,but never fully goes out,
   got another test to check,
  then a possible  stator rewind?  or Rotor,,or both,
  but the other alternative is fit VAPE electronic ignition and generator,dowside is you lose the electric start,
  more details  soon
Offline Skoti
Re: Yamaha CS5
« Reply #62 on: May 10, 2026, 06:54:35 PM »
Fitted VAPE about 10 years ago to a 1942 NSU and a Jawa 350, it's quality kit and has been absolutely trouble free.
But not cheap especially for the NSU 125ZDB.
But I'm aware you have problems with your ankle so perhaps electric start is important?
Skoti
1976 Honda CB750F1
Re: Yamaha CS5
« Reply #63 on: May 10, 2026, 07:16:43 PM »
I don't really need to kick start it
I can just lean over the seat and push the lever with my arm
Starts easily enough
But I like to press the button!!
Re: Yamaha CS5
« Reply #64 on: May 10, 2026, 09:55:56 PM »
Let me have a ponder on some test for you Ted before you remove anything
Re: Yamaha CS5
« Reply #65 on: May 11, 2026, 03:16:56 PM »
Just visited a local electrical rewind specialist
He suggests clean thoroughly,
Current can leak away using debris from the worn brushes
More news in a few days
Re: Yamaha CS5
« Reply #66 on: May 11, 2026, 04:42:24 PM »
If you can get it Armaclean is best or carbon tetrachloride but i think that is now designated as a "nasty"
Re: Yamaha CS5
« Reply #67 on: May 14, 2026, 03:04:00 PM »
an interesting morning,
cleaner spray brought up everything like new,
 rotor segments all good,no leakage to earth
  cleaned the stator and brushs
  brush 1 and 3 seem to be the power ,nice and clean,no leakage to earth,brushes 2 and 4 are earthed,so not so critical.
  started again,guess what,no change,still no charge
Re: Yamaha CS5
« Reply #68 on: May 14, 2026, 03:48:50 PM »
Does the electric starter work?
Re: Yamaha CS5
« Reply #69 on: May 14, 2026, 04:15:21 PM »
yes,
  but it seems slowish,
  but I am comparing it to the 500 and 200,which have different systems,
   the only electrical thing that really needs replacement is the ignition switch,it has been knacked ,with the centre core removable and all the pins missing
 would that make a difference?  my thoughts are it only turns a  contact unit to switch it all on
Re: Yamaha CS5
« Reply #70 on: May 14, 2026, 04:39:49 PM »
Just the lock part will make no difference, from what you described the problem is the regulator/cut out box, i have been trying to work out a test for it but having been away for 3 weeks work is hard!
Re: Yamaha CS5
« Reply #71 on: May 14, 2026, 04:56:50 PM »
John try this
aircooledclub.com/manuals/cs3b.pdf
I have screenshot the reg part and will read testing at work on sunday and get back to you
That should be aircooledrdclub.com/manuals/cs3b.pdf
« Last Edit: May 14, 2026, 05:02:31 PM by Bryanj »
Re: Yamaha CS5
« Reply #72 on: May 25, 2026, 05:13:06 PM »
I have tested the regulator,
No current being fed to activate the generator,
So I have sent it off to a place in Lincoln,
He specialises in old dynamo and control boxes,
Strips them out and converts them to solid state,
With updates, such as reverse polarity protection
Also will keep the electric starter
I also have been busy, putting a new rim on the rear wheel,
First ever wheel build
Also before and after wheel
Re: Yamaha CS5
« Reply #73 on: May 25, 2026, 09:03:26 PM »
Well done Ted, just takes patience mate, i would think the reg is a corroded contact of siezes pivot but if the man can convert it reliably thats good
Re: Yamaha CS5
« Reply #74 on: May 27, 2026, 07:14:34 AM »
Very satisfying to build these. The truing is therapeutic.
