Author Topic: What engine oil  (Read 14559 times)
Offline Alimacdee2
Re: What engine oil
« Reply #15 on: July 07, 2026, 08:40:26 PM »
I’m now using a 20/50 mineral oil, full circle really! I think it’s probably more appropriate for these older engines, these are hot running engines 20/50 at its hottest i see drops to 60psi on my bike,  a 10/40 or 10/30 synthetic non synthetic oil would reduce oil pressure, to main bearings,  the engineers that designed these must have calculated oil pressure according to engine clearances to match Oil and viscosity back then.
« Last Edit: July 07, 2026, 08:54:05 PM by Alimacdee2 »
1970 HONDA CB750
2002 Ducati Monster 750ie
1971 Triumph Trophy T100C
Re: What engine oil
« Reply #16 on: July 07, 2026, 10:52:40 PM »
I suspect that its complicated in that, as viscocity increases the flow rate decreases.
A similay grade synthetic oil would have less resistance but increased flow rate.
The corollary of that is a drop in pressure soley by the use of a thinner oil actually increases the amount of lubrication.
My memory of Jaguar & Mercedes  engines from the 1960's is that they ran on much lower oil pressures than the likes of BL.
When I ran an old Nissan Diesel 2.7 4 cylinder 4x4 the Nissan Owners Club were of the view that Mineral oil was best, I found that using fully synthetic engine oil of the same grade (10W/40)actually made the engine much quiter without any noticable loss of oil between services.
Offline Martin6
Re: What engine oil
« Reply #17 on: July 07, 2026, 11:36:49 PM »
Regarding the Honda, I agree with that, Ted. But on a well used oil pump and main bearings (and other tollerances), does that still hold true?
Honda itself said 20W50 is fine.
Re: What engine oil
« Reply #18 on: July 08, 2026, 08:06:57 AM »
I don't know the answer to that question, fluid dynamics was never my strong point, I've had lecturers tell me to think of pressure as Voltage, flow rated as Amps, resistance is a tricky one that has many variables depending on the fluid involved. A thin film of good oil might be better than a thicker film of mineral oil.
Interestingly the development of synthetic oil was initially based on longer service intervals. One issue was the build up of acidic waste in the oil from sulphates iirc. The game changer was to add micronised chalk to the oil to neutralise the acid build up.
Offline florence
Re: What engine oil
« Reply #19 on: July 08, 2026, 09:21:14 AM »
Should we not also consider the temperature of the oil and it's viscosity at start up, a critical time for the engine.  I certainly would not want 20w50 in a cold engine in the winter.  (Perhaps you don't ride in winter?)
Re: What engine oil
« Reply #20 on: July 08, 2026, 09:33:16 AM »
At one time you could buy pre-oilers for many cars, a servo pumped oil giving full oil pressure before you started the engine.
Re: What engine oil
« Reply #21 on: July 08, 2026, 02:03:58 PM »
If you rebuild a Merc V6or8 in an HGV you have to pressurise the oil system as the pump will not self prime
Offline Alimacdee2
Re: What engine oil
« Reply #22 on: July 08, 2026, 04:03:40 PM »
don’t think it’s a concern in the UK, even the North of Scotland it’s rarely that cold, I  usually drive all year round weather permitting when it’s dry, I keep bikes heated in winter to prevent condensation &oxidation forming on engine casings when temperatures drops
I’ve also previously found lower viscosity semi synth and full synthetic oils exacerbate problems with leaky cylinder head pucks, threads, and exhaust valve stems on the early cb750 on an older rebuild, and.. now that I’ve heard it, probably due to fluid dynamics and increased flow rates
« Last Edit: July 09, 2026, 04:05:37 PM by Alimacdee2 »
1970 HONDA CB750
