Brake caliper pivot pin
Topic: Brake caliper pivot pin (Read 10462 times)
Peterplank
Newbie
March 07, 2026, 01:57:57 PM »
Hello all,
Before I start hitting anything...Could anyone tell me if the caliper pivot just knocks apart or screws out ?
500-4 K1
DR-350
600RR7
Johnwebley
Re: Brake caliper pivot pin
March 07, 2026, 02:04:08 PM »
Should slide out,
Use plenty of penetrating oils
Suggest you put the tee piece in a vise
Try to move the caliper arm,
It should have O rings top and bottom on the shaft,
Plenty of gentle persuasion
Don't rush it
Remember to pack with grease on reassembly
Peterplank
Newbie
March 07, 2026, 02:09:36 PM »
Thankyou, about to clean, re grease and fit new o rings 👍
Could have sworn I was only doing the carbs 😆
500-4 K1
DR-350
600RR7
McCabe-Thiele (Ted)
March 07, 2026, 02:15:46 PM »
Reads like Mission creep.😀
Link to my full restoration
deltarider
My kingdom for a turkey!
March 07, 2026, 03:53:53 PM »
What's the issue? Greasing the pivot pin is NOT in the maintenance scedule. If there's no issue, leave it alone. With the front wheel out you can test if it swivels OK. Mine after 46 years is still untouched. When I breath hard towards it, it swivels. Good enough for me.
March 07, 2026, 04:53:46 PM »
No it isnt in the scedule BUT it is a necessary service item as found by multiple UK dealers workshops
McCabe-Thiele (Ted)
March 07, 2026, 08:19:14 PM »
Even with Honda quality, seals perish with age, those used in all weathers will eventually seize, mine was pretty corroded, possibly salt ingress.
I'm pretty sure a lot of our bikes avoid rain whenever possible so it should be a long term fix once new seals are fitted with grease that does not dry out with the heat of braking.
Last Edit: March 07, 2026, 11:17:37 PM by McCabe-Thiele (Ted)
Oddjob
March 07, 2026, 10:20:50 PM »
The main stand pivot pin isn’t in the maintenance schedule, neither is the rear brake pivot pin yet both require greasing every few years or they’ll either seize or worse oval out the frame mounts.
March 08, 2026, 01:15:52 AM »
Very true Ken
Grewth
SOHC Member
March 09, 2026, 12:21:15 AM »
I always roast mine on the gas cooker hob.
Works every time with caliper swing arms, and also caliper bodies with seized pistons.
Good ventilation required unless you want to be overwhelmed by smoke inhalation
Murf
SOHC Expert
Reply #10 on:
March 09, 2026, 04:04:30 PM »
Some fast running also required to escape from the wife 😂.
Johny Boy
Newbie
Reply #11 on:
March 10, 2026, 11:06:56 PM »
Mine was a nightmare, blow torch and and a thorough beating, thought it would never move
CB550 (85% there)
New BSA Goldstar (my daily)
MV Agusta F4 750 Senna (Front room love affair)
BSA bantam (my constant pain in the arse)
