Author Topic: What length chain do you CB500 owners fit: 98 or 100 links?  (Read 20818 times)
« on: March 13, 2026, 10:55:17 AM »
What length chain do you CB500 owners fit: 98 or 100 links and why?
Re: What length chain do you CB500 owners fit: 98 or 100 links?
« Reply #1 on: March 13, 2026, 11:49:13 AM »
My own answer is I don't know,
Most chains I buy are to long, so I shorten them by several links
Online Bryanj
« Reply #2 on: March 13, 2026, 11:52:05 AM »
Same as John
Offline mickwinf
« Reply #3 on: March 13, 2026, 12:09:32 PM »
Depends on amount of teeth on sprockets. I had a 550 rear sprocket on my 500 which needed a 100 links but now changed to the correct 500 one and chain needed a link removing to fit.
Offline florence
« Reply #4 on: March 13, 2026, 12:51:18 PM »
There is not a correct answer here.  I agree with John and Bryan, just put it together and shorten to a point where you have plenty of adjustment space.
« Reply #5 on: March 13, 2026, 02:55:25 PM »
I may have found confirmation for what I have once read some 45 years ago. It is in this site for chains and sprockets sets: https://www.kettingkits.nl/nl_nl/route
I find most chain sites next to useless, but this is actually a good one. It's in Dutch, but don't let that stop you. It's all about digits, not words.
Select 1. Honda, 2. 550 and 3. CB550. This site suggests what these Honda's originally had; for the CB550 100 links and sprockets 17 and 37. Now this site offers you options to varify the size of sprockets [configureer uw kit] and now comes the interesting bit: if you have the CB550 selected and change the original rear sprocket from 37 into 34, the program reacts automatically by reducing the 100 link chain to a 98 one. Maybe this is a confirmation for what I have read long time ago. Can you guess what it is?
« Last Edit: March 13, 2026, 03:17:30 PM by deltarider »
Online Bryanj
« Reply #6 on: March 13, 2026, 04:04:46 PM »
Our point is that it is easier, and cheaper, to buy a box chain at 110 and cut a bit off, when Reynolds still produced motorcycle chain dealers bought it in 50ft rolls and sold you whatever you wanted, now bean counters say it isnt worth stocking all the different lengths just one the longest needed and shorten it
Offline mickwinf
« Reply #7 on: March 13, 2026, 04:29:40 PM »
deltarider that agrees with what i said, i changed from a 37t to a 34t and had to shorten from 100 links to 98.
« Reply #8 on: March 14, 2026, 08:20:27 AM »
Here is the confirmation I was looking for. With a final reduction of exactly 2 (17/34) and a 100 link chain, you run the risk of uneven wear, as always the same link 'lands' in the same spot on the sprocket. Going to 98 links changes that and wear will be spreaded equally. So the CB500 had 98 links and when Honda decided to market the CB550K3-ED as a touring bike and therefore changed the 17/37 into 17/34, Honda consequentely changed the chain to a 98 link one. Does this make sense or am I overlooking something?
« Last Edit: March 14, 2026, 08:24:06 AM by deltarider »
« Reply #9 on: March 14, 2026, 09:24:00 AM »
Does that in reality stack up to give the outcome suggested  ?  I'm not immediately convinced that's the case.
If it were a pair of gears, then the 1/2 ratio could have some impact , possibly.
With a chain of X no links, you'd divide the links by the tooth no, wouldn't you ?
And so, 100/ 17 or 100/34 doesn't divide equally to give a repeated engagement "wear pattern" anyway.
Taking the 100/17 would see the repeated engagement through the two at 5.88 ..... and so would see the chain effectively cycle through all of the links in rotation.
« Reply #10 on: March 14, 2026, 10:36:44 AM »
Wouldn't you also need a chain of 102 links to give any semblance of repeatability  ?
« Reply #11 on: March 14, 2026, 12:09:54 PM »
100:2= 50 (still an even numer), 98:2= 49 (odd). Is it my intuition that tells me there's the answer?  ;)
« Reply #12 on: March 14, 2026, 12:28:41 PM »
And what impact does that "50" have ?
Both 98 & 100 aren't exactly divisible by either 17 or 34, making the chain effectively "cycle" around the sprockets throughout its use. Meaning, that each tooth form will interact with a different chain link in successive rotation. That over a period of time until the mathematics repeats, eventually.
« Reply #13 on: March 14, 2026, 12:31:25 PM »
You seem to be forgetting that only the 550 has a chain length of 100, the 500 is 98. The 500 uses 17/34 sprockets whereas the 550 uses 17/37 sprockets so the maths is different.
« Reply #14 on: March 14, 2026, 01:16:18 PM »
This reminds me of the old brit bikes when the cam gear is always double the crank,but the intermediate gear had an odd number of teeth to spread the wear,so called hunting tooth idea
No idea if this much thought was invested in the final drive
