Author Topic: Importing a bike and NOVA  (Read 22871 times)
Re: Importing a bike and NOVA
« Reply #45 on: November 19, 2026, 09:33:49 AM »
Incidentally, I had a 500 Daytona back in the day as a daily rider and used to rev the nuts off it regularly. It never threw a rod, but the bushed main bearing was a regular wear problem.Does yours have the bush or  the later 68/69 bearing journals?
Offline Alimacdee2
« Reply #46 on: November 19, 2026, 12:09:54 PM »
thanks for those comments again, been looking at used/nos rods, erring towards Hepolite H-beam rods which are weight matched & balanced, no bushes roller bearing on drive side ball bearing timing side.
I would like the full treatment of course crack testing new rods and then new piston’s all dynamically balanced, my plan at this stage is new rods new valves, may have the crank crack tested locally now . The bike didn’t cost much so trying to keep the cost down, until it’s back to a certain standard overall.
Quite like this video must test mine see if I get a tune,  and whether it is an indication
https://www.facebook.com/seagerengineering/videos/ring-testing-triumph-crankshafts/1558168536314936/
« Last Edit: November 19, 2026, 02:01:34 PM by Alimacdee2 »
1970 HONDA CB750
2002 Ducati Monster 750ie
1971 Triumph Trophy T100C
« Reply #47 on: November 19, 2026, 04:03:07 PM »
I’ll be interested to see what balance factor you choose.
« Reply #48 on: November 19, 2026, 04:15:30 PM »
Also, you may find this useful, if you haven’t already got a copy of course.
Offline Alimacdee2
« Reply #49 on: November 19, 2026, 07:26:26 PM »
Thanks interesting reading,  I think I’ll stick with nos same weight conrods and pistons, from what I’ve read balancing on these smaller engines isn’t as critical if you stick to factory spec conrods and pistons, the t100c with its single carb is a lower revving motor ideal for green laneing
Be interesting when I empty the sludge trap may give an idea of the condition how it’s been used.
Text:
Because the 500cc unit-construction engine uses a short stroke and relatively light reciprocating parts, it is naturally much smoother than Triumph's 650cc and 750cc twins, making balancing optional for standard road rebuilds.
When Builders Skip Balancing
• Stock Street Rebuilds. If you are reusing original-weight pistons and connecting rods for everyday road riding, most builders simply clean out the sludge trap and reassemble the engine without paying for dynamic balancing.
• Marginal Gains on 500cc Twins. According to The Triumph C Range, dynamic balancing offers only a marginal smoothness improvement on smaller 350cc and 500cc parallel twins compared to larger-displacement models.
« Last Edit: November 19, 2026, 07:28:55 PM by Alimacdee2 »
1970 HONDA CB750
« Reply #50 on: November 19, 2026, 07:59:17 PM »
Good luck and keep us informed.
