Author Topic: Clutch Lever swytch - advice please  (Read 3853 times)
Offline Alexandlinda
« on: March 27, 2026, 05:59:22 PM »
I have inherited a CB750 K6. When I stalled it, I pulled the clutch lever and hit the start button but no deal! Had to find neutral to start again.
When I later checked the clutch lever there is no little switch there. I'm sure from my ageing memory that there should be a switch so when you pull the lever in it will enable you to restart in any gear.
I can see the little hole in the lever housing but where would I locate the wires that connect to the switch?
So my question is what do I need, where to get it and how to fit it? Any advice would be appreciated.
Thanks.
« Last Edit: March 27, 2026, 06:05:06 PM by Alexandlinda »
Honda CB750 K7 - 1977 FOR SALE!
Honda CB750 K6 - 1976
Royal Enfield Interceptor - 2020
Re: Clutch Lever swytch - advice please
« Reply #1 on: March 27, 2026, 06:17:14 PM »
Its the same switch as the drum braked 125 with different colour wires, you remove the lever, feed the wires through the hole from the lever side and push plastic switch home fully.
It conects in the headlamp shell, you will have to check a wiring diagram for colours and should still be available from Honda, check for part number on cmsnl
Superceeded part number 35340329003
« Last Edit: March 27, 2026, 06:22:13 PM by Bryanj »
« Reply #2 on: March 27, 2026, 06:30:53 PM »
This is a brake light switch off fleabay, about 1/3 price of DSS
« Reply #3 on: March 28, 2026, 09:00:44 AM »
Thanks Bryan. Found it on Fleabay and ordered. I had a feeling the wires would be inside the headlamp shell. Just need a coloured wiring diagram.
« Reply #4 on: March 28, 2026, 10:23:29 AM »
The colours on the switch will be different to those in the loom as the switch is for a brakelight but it works fine
