Author Topic: CB550 rear brake spring bracket  (Read 13869 times)
Offline Johny Boy
« on: March 31, 2026, 05:35:23 PM »
Hi all,  I thought I would share a little win!
The bracket for the rear brake switch appears to be discontinued.
I have made one from a standard 1 quid 50 x 50 x 20 bracket from Screwfix.
Drilled out one hole to dia 11 to suit the rear engine mounting.
Drilled the second one to dia 13, cut 25mm off the end and added the slot.
CB550 (85% there)
New BSA Goldstar (my daily)
MV Agusta F4 750 Senna (Front room love affair)
BSA bantam (my constant pain in the arse)
Offline Johny Boy
Re: CB550 rear brake spring bracket
« Reply #1 on: March 31, 2026, 05:36:22 PM »
With switch fitted
CB550 (85% there)
« Reply #2 on: March 31, 2026, 05:39:10 PM »
Excellent
« Reply #3 on: March 31, 2026, 06:15:30 PM »
Nice bit of adaption. :D
Offline Towsejames
« Reply #4 on: April 01, 2026, 07:26:20 AM »
This sounds very interesting. Do you have any photos?
I only ask as I’ve just bought a 1976 cb550F and the kick start hits the rear brake lever, meaning the kick start can’t be used. I’ve tried looking at some pictures of bikes in that area off google photos and similar but haven’t found any real reason why mine hits.
Along with this I am missing the rear brake lever return spring and currently the lever only has the brake light switch spring to hold it up. I’ll try and grab some photos later on.
I’ve heard the cb550K and the cb550F have different kick stat lever and/or brake lever? (I think my bike could be abit of a mismatch, as it has a CB550F frame number but 550K tank and side panels.) But difficult to know which bits are which.
Any help would be appreciated.
Offline Johny Boy
« Reply #5 on: April 01, 2026, 08:53:08 AM »
Hi, I haven't fitted my kick-start yet, but I've had a quick look on CMSNL and it appears the brake levers are different
CB550F2 Part number:
46500390000
CB550K3 Part number:
46500404670
CMSNL is a great website for Part identification and supply, they have exploded assembly drawings for each version of the Honda models
CB550 (85% there)
Offline Johny Boy
« Reply #6 on: April 01, 2026, 08:57:31 AM »
Also, Oddjob found this on ebay for me the other day
Return spring, discontinued now, so I would snap this up
https://www.ebay.com/itm/286777387009
CB550 (85% there)
Offline Towsejames
« Reply #7 on: April 01, 2026, 11:18:03 AM »
Thanks for the advice, I do need one of those springs. Did you have to pay additional import tax with it coming from the US to Britain?
Offline Towsejames
« Reply #8 on: April 01, 2026, 11:26:53 AM »
Ah they won’t deliver to my address anyway with it coming from the US. Did you get yours delivered to the UK?
Offline Johny Boy
« Reply #9 on: April 01, 2026, 12:00:37 PM »
I actually bought a kit of second hand parts from Bulgaria which had a spring in it.
I'm surprised they won't deliver to the UK?
Maybe try again as that is the only other one I could find anywhere
CB550 (85% there)
« Reply #10 on: April 01, 2026, 01:44:03 PM »
I bought a good used  spring from two wheel spares, had to buy the lever as well.
« Reply #11 on: April 01, 2026, 06:25:37 PM »
The rear brake lever on a 550f is flat steel, on a 550k it’s round. If yours is round the kickstart lever will hit it.
Offline Towsejames
« Reply #12 on: April 02, 2026, 10:47:15 PM »
Here is what’s is happening. I think the footpeg and brake switch are mounted incorrectly and maybe I have the wrong brake lever and or kick start lever?
Offline Johny Boy
« Reply #13 on: April 02, 2026, 11:14:59 PM »
Hi, mine is mounted on the bolt above where yours is, it's the rear upper engine mounting bolt.
The bottom of the spring hooks onto the inside of the pivot part item 12, in the notch
But mine is a homemade bracket!
CB550 (85% there)
Offline Johny Boy
« Reply #14 on: April 02, 2026, 11:38:43 PM »
I've just had a look at my kick start lever, it does seem to have much bigger offset than yours, but it has obviously also hit the brake lever a few times in the past. Although mine came without the brake lever
CB550 (85% there)
