Author Topic: Indicator relay wiring  (Read 4020 times)
Offline Johny Boy
« on: April 10, 2026, 10:21:55 AM »
Hi, me again, thanks for all the help so far.
This one is for the electrically minded amongst you
Lights and horn now working... ;D
I have a 2 pole relay for the indicators, with B and L markings.
As I understand it,  B is the battery feed and L the load from the switch.
The handbook wiring diagram shows these as black and green respectively.
I have these from the loom, although the green wire is about 2" shorter than the black and doesn't seem long enough to comfortably reach the relay and I also seem to have a spare white wire, same length as the black one and I can't see where this would connect
Any ideas on this?
CB550 (85% there)
New BSA Goldstar (my daily)
MV Agusta F4 750 Senna (Front room love affair)
BSA bantam (my constant pain in the arse)
Re: Indicator relay wiring
« Reply #1 on: April 10, 2026, 12:16:27 PM »
Nooooo!!!
Black is power, grey is load to switch, green is earth for the original 3 pin relay
Offline Johny Boy
« Reply #2 on: April 10, 2026, 12:23:51 PM »
Oh yes,  Gr is grey not green, thanks for that
CB550 (85% there)
