Author Topic: Front brake switches don't seem to last long...  (Read 11951 times)
Offline TrickyMicky
Re: Front brake switches don't seem to last long...
« Reply #15 on: May 17, 2026, 07:53:05 AM »
If you still have not removed the switch, maybe try applying plenty of pressure through the brake lever then give a sharp tap to one of the hexagon flats with a small jhammer or a screwdriver handle. This used to work sometimes on compressed air lines if a valve played silly buggers.
Offline Mikep328
« Reply #16 on: May 19, 2026, 09:01:26 AM »
Thanks, I should have tried that but replaced the switch before reading that thread.  Works fine now - hope the switch lasts longer than two years!!!
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
