Author Topic: 750F1 gear change issue  (Read 16602 times)
Offline neat street
Re: 750F1 gear change issue
« Reply #15 on: May 02, 2026, 01:19:36 PM »
Thanks K2 K6 and Skoti, (K2 K6) problem is that when you take out the clutch spings ect, you have no drive from the clutch so it just turns freely... Skoti, thanks, that will be the solution to undoing, but now need to torque up and have to lock up? I am not sure how to do this without damage. Thank you both for your ideas and help.
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Offline Skoti
« Reply #16 on: May 02, 2026, 01:35:49 PM »
There's a special tool required for holding the clutch basket.
https://www.honda-classics.co.uk/shop/Tool-Set-Clutch-Basket-Holding-&-Centre-Nut-Tools-HWT052-p383119625
Skoti
1976 Honda CB750F1
Offline neat street
« Reply #17 on: May 02, 2026, 01:57:07 PM »
Thanks Skoti, that makes sence, I will try and make something. appreciate your help
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
« Reply #18 on: May 02, 2026, 10:01:03 PM »
If you imagine a set of mole grips with welded on legs turned at a right angle at the end that is what kawasaki sell to dealers as a clutch centre holder, have seen similar on fleabay will try and look
« Reply #19 on: May 02, 2026, 10:03:44 PM »
Found one, pic of page attached, DO NOT ASK FOR A LINK i am too bloody old and tech non savy to do that.
There are cheaper on ebay and from foreign sellers just type into google kawasaki clutch centre holdin tool
« Last Edit: May 02, 2026, 10:07:26 PM by Bryanj »
Offline neat street
« Reply #20 on: May 03, 2026, 08:10:12 AM »
Thank you Brian and all for your help, I managed to make one out of a steel stake that have a bend in them, dont look pretty and has two legs instead of four, but done the trick :-)
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
