Author Topic: cb400-four speed.  (Read 24854 times)
Online Mikep328
Re: cb400-four speed.
« Reply #15 on: May 04, 2026, 10:07:45 AM »
The red ones were far more reliable; the additional speed from the yellow ones compromised engine integrity!
OK...that's not true of course...
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
« Reply #16 on: May 04, 2026, 12:53:39 PM »
Thanks Tricky Mick for the seat info.  I managed to undo the lock and open the seat.   The air Filter looks brand new, so I will have to investigate further.
If the weather holds today I will try some further tests.  I have compared the speedo with a Sat-Nav and they are within 2 mph of each other.
Mine is a Red bike, but I have several litres of JCB Yellow Paint, if all else fails. . . !
Something that may need double checking, some years ago I had a honda that had stood for a while, that air filter looked new, but just would not flow properly, giving rich mixture and "capped" power output.
Whether it had been damp and possibly compromised, or something else that I couldn't readily explain, the result was clear and when swapped it was fine.
Tenuous link, but a possibility to consider.
Online Athame57
    • SeaWitch Artist
« Reply #17 on: May 04, 2026, 05:23:37 PM »
But is true that the yellow ones are faster, after all Dave told us so!  ;D
1978 CB400F2 named Elen.
Offline exvalvesetdabbler
« Reply #18 on: May 04, 2026, 06:05:56 PM »
Mine is red and an indicated  110 was regularly achievable in the 80s with my girlfriend on the bach.  It was dead flat where we lived, long straight roads and no traffic.
Not sure if I would be brave enough now. Too many other idiots on the road.
The local bobby only had a hilman advenger so the best he could do was tell my dad in the pub on a Friday darts night.
That was more of a deterrent than being brought before the magistrate.
 Dave
Offline scifi
  • C90, TL125,C11, 3 1/2 HP., cb250 cb360, cb400-4.
« Reply #19 on: May 04, 2026, 09:50:04 PM »
Well after looking at the air filter beneath the seat, I removed the air cleaner top lid and went for another test ride.
This time 70 came up after about 1/4 mile straight, with more to come.
I found that the air intake was masked by the seat, as the following photo may show..
The bit between the screwdrivers is the only bit not obscured by the seat....
« Reply #20 on: May 04, 2026, 09:58:29 PM »
Something not fitting right there
Offline TrickyMicky
« Reply #21 on: May 04, 2026, 11:16:01 PM »
If you have the standard seat, are all the rubber spacers fitted as per the photo? These keep the seat base clear of the air intake. If the seat has been allowewd to settle too low, this could also be why the lock jammed.
Offline scifi
« Reply #22 on: May 05, 2026, 11:14:01 AM »
Thanks Tricky Micky, my seat does not have those 4 rubbers, or anywhere to put them.  So it looks as if I will have to run with the filter uncovered.
Got a new seat lock on order, from China, should be here by end of the month.
« Last Edit: May 05, 2026, 11:20:47 AM by scifi »
« Reply #23 on: May 05, 2026, 12:41:46 PM »
My 400 has a type of plastic seat base not steel.
I don't know if it's original or not.
Offline TrickyMicky
« Reply #24 on: May 05, 2026, 02:07:14 PM »
Original ones are steel, Ted. Even the new reproduction ones from DSS have a steel base.
« Last Edit: May 05, 2026, 02:09:28 PM by TrickyMicky »
« Reply #25 on: May 05, 2026, 08:52:50 PM »
On the upside it will not rot away, it has the rubber buffers, the seat hinge and catch work so I assumed it was original. 👍
« Reply #26 on: May 05, 2026, 10:32:48 PM »
DS first "pattern" seats were plastic based and tended to rock a bit front to back, i have an unused one somewhere for a 500
« Reply #27 on: May 05, 2026, 11:18:37 PM »
If you fit a pattern seat from DSS make sure the hinge and seat lock brackets are in the correct place, mine were miles out to the extent the front of the seat was so far forward when I fitted the hinges it fouled on the back of the fuel tank with big rucks in the cover. I sent the first seat back and the replacement still needed the seat lock and the hinge plate modifying to elongate the mounting holes by 8mm to fit properly.
To be fair to DSS though he accepted the original seat back despite me adding the Honda logo on the back using a stencil so I can't complain and he was very fair about it.
Offline scifi
« Reply #28 on: May 24, 2026, 11:03:10 AM »
Thanks everyone for your replies.  I have just received a new seat lock from China ( £9 delivered.).
With the top removed from the air filter box, the 400-4 now goes faster than I will ever need.
Online Mikep328
« Reply #29 on: May 24, 2026, 11:48:11 AM »
"With the top removed from the air filter box, the 400-4 now goes faster than I will ever need."
Heck my very first motorcycle, a 125cc Kawasaki two stroke with probably 12-13HP could go faster than I ever really needed!  :)
But somehow I still managed to "need" 160+ HP Ducati sport bikes, etc...  But I'm working my way back down with my 65HP V7 850!!
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
