Author Topic: Wanted 750 swing arm bearing tube  (Read 3214 times)
Offline Kev Bishop
« on: May 03, 2026, 03:49:05 PM »
Hi looking for a bearing tube if that’s what you call it for a 750 SOHC wear on the Bering surface not a problem as I’m using taper bearings and will be cutting it down and using it for a spacer . UK preferably
Cheers Kev
Re: Wanted 750 swing arm bearing tube
« Reply #1 on: May 03, 2026, 07:01:31 PM »
The taper roller bearing conversion uses a different collar than the standard one. Not sure you can adapt it tbh. It may be possible with a lathe I suppose.
