Author Topic: cb 550 k3 carb intake rubber  (Read 5682 times)
Offline gaz172
« on: May 11, 2026, 08:26:53 PM »
 I've found a split in my air box to carb rubber, i was wanting to replace it but it seems nowhere sells them, has anybody any idea where i could get a replacement,or an alternative that fits ? thanks
1976 Honda 400/4 x2
1981 Suzuki gs1000e
1981 suzuki gs1000g
2024 bsa goldstar
1983 Honda cb750f
1994 Ducati 600 monster
1958 Matchless 350
1953 matchless g9
1979 Honda 550k3
1978 750 phil read replica
Re: cb 550 k3 carb intake rubber
« Reply #1 on: May 11, 2026, 09:04:46 PM »
Do you mean carb to head or airbox to carb
Offline gaz172
« Reply #2 on: May 11, 2026, 09:19:18 PM »
airbox to carb
1976 Honda 400/4 x2
1981 Suzuki gs1000e
1981 suzuki gs1000g
2024 bsa goldstar
1983 Honda cb750f
1958 Matchless 350
1953 matchless g9
1979 Honda 550k3
Offline Peterplank
« Reply #3 on: May 11, 2026, 09:26:04 PM »
I’ve got a couple off 500, used but ok… I think the same ...you can have if you like :o)
500-4 K1
DR-350
600RR7
« Reply #4 on: May 11, 2026, 09:57:07 PM »
550 has different rubbers to 500, there was a member on the US forum that was making the 550 rubbers otherwise they only come with the plenum chamber if its available
Sorry 550 K3 is different as it has PD carbs
« Last Edit: May 11, 2026, 10:32:09 PM by Bryanj »
« Reply #5 on: May 11, 2026, 10:32:52 PM »
I should clarify Bryans comments. It’s only the 550K3 which has different intake rubbers than the 500, the 550F has the same as the 500. It’s due to the different carbs fitted to the K3, which were PD carbs. The 500 and 550F share essentially the same carbs.
« Reply #6 on: May 12, 2026, 09:54:29 AM »
Offline gaz172
« Reply #7 on: May 12, 2026, 04:19:29 PM »
unfortuntely its number 1
1976 Honda 400/4 x2
1981 Suzuki gs1000e
1981 suzuki gs1000g
2024 bsa goldstar
1983 Honda cb750f
1958 Matchless 350
1953 matchless g9
1979 Honda 550k3
« Reply #8 on: May 12, 2026, 07:04:50 PM »
Thats the usual one that splits
« Reply #9 on: May 12, 2026, 07:08:59 PM »
You need 17310404670 but it is discontinued and over £100
« Reply #10 on: May 12, 2026, 07:10:22 PM »
There are sets available at CB-Four.com just found them, supposedly in stock.
Offline gaz172
« Reply #11 on: May 13, 2026, 05:44:57 PM »
Thats them (hopefully). got them ordered anyway, thanks for the help.
1976 Honda 400/4 x2
1981 Suzuki gs1000e
1981 suzuki gs1000g
2024 bsa goldstar
1983 Honda cb750f
1958 Matchless 350
1953 matchless g9
1979 Honda 550k3
« Reply #12 on: May 13, 2026, 06:29:57 PM »
You’re welcome Gaz, I’m pretty good at finding stuff others struggle to find.
