Refurbing Carbs - In what condition should you replace the jets
Topic: Refurbing Carbs - In what condition should you replace the jets (Read 5878 times)
Neilw
SOHC Member
May 12, 2026, 05:31:05 PM »
I'm tearing down the carbs of my 1978 CB550 F2, i've already cracked one of the Float bowls trying to get the drain screw out and lost a spring, which NurseJulie has very kindly donated a replacement.
I intended to clean everything, which I can see is going to take some time using Carb Cleaner.
I was going to keep all the jets, clean them, and replace the rubbers, etc. Most of the jets are in a state, and will need carb cleaner and something abrasive, like steel wool, to clean them. They most typically look like the example in the picture.
Are these too far gone, and should I go for a rebuild kit? Or should I persevere?
Orcade-Ian
Re: Refurbing Carbs - In what condition should you replace the jets
May 12, 2026, 06:12:38 PM »
Perceived wisdom is that the originals (they look like they could easily be) are far better than some of cheap replacements, so better to keep those. I would not use wire wool but a good soaking in a small jar with carb cleaner in (even brake cleaner works well) might get most of the gunge off. A light rub over the external surfaces with a grey scotchbrite pad, should have them clean again. You can keep checking to see if all holes are clear and keep going if not. If you know anyone with an ultrasonic cleaning bath (jewellers, dentists 🙈) they might help you.
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
May 12, 2026, 07:04:18 PM »
Or buy an ultrasonic cleaner that 1 carb fits into, your carbs are relatively easy to de rack and reassemble unlike the PD ones
Oddjob
May 12, 2026, 07:06:04 PM »
Go to a main supermarket and the dental hygiene section. Buy an assortment of Interdental brushes. Use these to clean out the jets along with some carb cleaner. The bristles are nylon and will cause no damage.
Skoti
May 12, 2026, 07:42:47 PM »
Once cleaned test if the carb needles will pass straight through the needle jets unobstructed, if so the jets and needles are worn and you'll be better renewing them.
https://www.cmsnl.com/honda-cb550f2-super-sport-550-four-1977-england_model17121/needle-setjet_16012390004/
I've found the other jets don't normally wear much, unless someone's had a go at cleaning them out with abrasive wire etc.
Also agree that genuine Honda jets are the only way to go if available.
Good luck
Last Edit: May 13, 2026, 08:50:26 AM by Skoti
Skoti
1976 Honda CB750F1
exvalvesetdabbler
May 12, 2026, 08:06:22 PM »
You need to examine the top oraface of those emulsion tubes to see if corrosion or wear has enlarged the hole. If it has look forward to some black spark plugs. For the needles, can you feel the machining marks with your thumb nail or are they well polished.
What about the float valves, is there noticeable ridge worn on the conical tip.
The jets should be ok so long as you don't open them up by poking steel wire through them.
Main jets I put string through and rub them up/down the taught string.
Pilot jet - copper wire out of mains cable flex.
Regards
Dave
deltarider
My kingdom for a turkey!
May 13, 2026, 10:24:12 AM »
I can testify the CB500/550 carb brassware goes a looong way. The last time I had it out, I couldn't detect any wear. To me that's no wonder. This may sound blasphemous to some, but the CB500/550 engine is nothing more than 4 125cc lawnmower engines that happen to share one and the same crankshaft. No less than 4 carbs for 500cc displacement!
On my odo: 142.000km. Let's say the average fuel consumption has been 1 liter for every 17.5km. So the total amount of fuel consumed has been some 8000 liters, which is 2000 per carb.
Below the pics I took. Now you
might
think you see a very little wear on the floats needles. There isn't. I have felt with my nail a dozen times if I could detect even the beginning of a ridge. Well, there isn't. What you see is merely optical. If I cannot detect any wear and have no symptoms either, I see no reason to fix what ain't broken.
Our brothers across the pond have a different attitude. They reason: if aftermarket parts are on the market, it means there is a demand and there is problem to be solved. And as always, they are happy to buy stuff.
Now, it could well be that other motorcycles
do
need replacement of the brassware - I have once heard a mechanic complain about some model Goldwing - ours just happen to prove very durable. Enjoy!
Last Edit: May 13, 2026, 02:31:18 PM by deltarider
Oddjob
May 13, 2026, 04:18:22 PM »
My 1971 CB500 has 423000 kms on it, my 1972 one has 268000 kms. Both are still using the same carbs it came with from new. No jets have been replaced on either. Although the 71 one had the main jets changed when it was being raced but back to the old ones when I stopped. They’ve occasionally leaked from the overflow but never when leaded petrol was available. Both banks have been apart a few times for maintenance and painting.
If you can’t find a float bowl in a few weeks Neil let me know. I have a bank of carbs which I’ve broken for spares lying about. However my medical condition isn’t the best at the moment so I’d prefer not to have to rummage in the garage if I can help it.
Where in the UK are you Neil? I think I’ve asked that before for some reason. Maybe alter your profile to include it?
Sesman
May 13, 2026, 04:35:09 PM »
I would have no qualms about hoking out a blocked jet with proprietary probes. Just don’t be aggressive and use a sensibility sized probe. The jets are made of brass, not cheese. Stubbornly blocked pilot jets can cleared by heating via a gas flame and probing with a wire to clear the ash. I know cos I’ve done it successfully.
For example, clearing a #40 jet with a #38 probe is highly unlikely to change the jet diameter by a demonstrable amount - think cross sectional area and percentage change. It’s highly unlikely the CSA change through cleaning could approach a CSA enlargement that would be equivalent to a change in jet size!
Last Edit: May 13, 2026, 04:42:09 PM by Sesman
deltarider
May 13, 2026, 09:35:03 PM »
This is what I use: stranded copper wire.
Last Edit: May 13, 2026, 09:38:51 PM by deltarider
Sesman
Reply #10 on:
May 13, 2026, 10:25:47 PM »
As good as anything. I use guitar string.
Johnny4428
Reply #11 on:
May 14, 2026, 06:42:40 AM »
Guitar string if your tuning your carbs! 😂
deltarider
Reply #12 on:
May 14, 2026, 06:56:27 AM »
I've never tried it, but how about a temperature shock? Put jets in the freezer and then submerge them in boiling water. I've used very poisonous Yamaha carb cleaner in the past. Outboard workshops will not hand this easily to you though. For health reasons.
