Author Topic: K3 starter not working on switch  (Read 2760 times)
Offline Johny Boy
« on: May 21, 2026, 12:53:24 PM »
Hi all, I'm having an issue with the starter motor not turning on the button.
I currently have the ignition hot wired, as I'm fitting a Moto Gadget ignition switch
Lights, horn etc all work fine , I.e. I have switched 12v working and the charging circuit works
I have a signal coming from the starter button (resistance change), and the headlight dims when I press it.
The clutch switch is also giving out a signal but I have bypassed it at the moment for convenience, as I don't have a signal from the neutral switch yet.
I have replaced the starter solenoid switch with a new repro one.
If I jump the solenoid it will turn over and start up just fine. But not on the button.
Does anyone have any ideas what I should check next?
John
CB550 (85% there)
New BSA Goldstar (my daily)
MV Agusta F4 750 Senna (Front room love affair)
BSA bantam (my constant pain in the arse)
Re: K3 starter not working on switch
« Reply #1 on: May 21, 2026, 03:13:54 PM »
I think the K3 put power to the solenoid as against earlier bikes grounding the solenoid, the plastic insert inside the switch degraids and falls apart and is not available seperately, only as a complete RH switch.
In the US where they have headlight on all thectime its worse as pressing the button turns the headlamp off before connecting the starter.
Firstly check out how your system works then check contiuity in wiring and connectors.
Also look at solenoid and try powering direct with a jumper wire BE CAREFULL some pattern solenoids have wrong colour wires and can be wired internally totally different
Offline Rayzerman
« Reply #2 on: May 21, 2026, 04:17:00 PM »
On some of these vintage Hondas, in the case of the switch being a grounding circuit, on some switches there's a metal part that grounds on the handlebars, and you may have to "fix" it by making sure it does make good contact with the bars....  on others, there were wires inside the handlebars.
I imagine you could turn the ignition switch on and test there is 12V already at the solenoid, in which case, the switch will be the ground circuit???
Regardless, I'd disassemble the switch and give it a good clean while you're in there.
'72 CB350F, 2010 CBF1000FA
Offline Johny Boy
« Reply #3 on: May 21, 2026, 06:25:27 PM »
Thanks both, my switch gear is new, reproduction ones, so the headlight is on as soon as the ignition is on, and I was assuming that as it dimmed when I press the starter all was good. However my handlebars are black in colour and I've just checked they do not act as a ground and if a ground was required then this might be the issue, I'll check the 12v to the solenoid as well though.
Thanks again, hopefully that's the answer
CB550 (85% there)
« Reply #4 on: May 21, 2026, 09:19:23 PM »
If your headlight is on all the time you should have the changeover starter button where the headlamp goes out when button pressed, if not you may have a miss match of pattern parts
