Author Topic: Castrol Edge Pro 0W/20 engine oil  (Read 2804 times)
Online McCabe-Thiele (Ted)
« on: May 23, 2026, 11:02:21 PM »
I was charged £87.84 (inc VAT) for 6.1 Litres of oil when I had my Volvo Serviced, on top of that I was charged a disposal levy for the waste oil.
I have a bottle of Top up oil in Volvo packaging that states its Castrol Edge Pro 0W-20 meets specification VCC-RBSO-2AE.
It must be a good little earner for Castrol who sell Castrol Edge Pro 0W-20 with a variety of slightly different specifications for Volvo, Ford, Jaguar Land Rover, Vauxhall, each presumably with a specific additive for hybrid, turbo variants etc.
Is it likely at the Castrol Refinery make so many variations of Edge Pro 0W-20 oil?
Is it badge (ok bottle) engineering to fleece customers, the cynic in me thinks it's probably all the same oil until it's in the bottling plant, an appropriate label is then affixed at the end of the line?
« Last Edit: May 23, 2026, 11:04:20 PM by McCabe-Thiele (Ted) »
Re: Castrol Edge Pro 0W/20 engine oil
« Reply #1 on: May 24, 2026, 06:53:35 AM »
My guess is its all the same oil and its tested to all the specs and passes but they only write the individual one on the conforming bottle/lable.
I am still changing my own and buy mannol from ebay
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #2 on: May 24, 2026, 08:29:43 AM »
Don't worry Ted, the price of your oil (and road fuel/heating oil) will soon come down now that the Very Reverend Donald has sorted the mess out.
As you say - badge (bottle)engineering!
Ian
Forgot to add :
BP Chemicals in Saltend Hull (where my then girlfriend worked in the 70's) used to buy 5 gallon 'Robbican' drums of 20/50 Orobis oil, which was the same stuff that was branded as 'BP Visco Static' but the Orobis was a fraction of the 'Genuine' stuff.
« Last Edit: May 24, 2026, 08:37:13 AM by Orcade-Ian »
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Offline Lynx
  • Repair & Despair Under One Roof
« Reply #3 on: May 24, 2026, 08:37:57 AM »
There's a big mark up on that Ted. I serviced my Volvo myself with the same oil from Halfords and it was half the price!
Sent from my 24040RN64Y using Tapatalk
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
« Reply #4 on: May 24, 2026, 09:41:38 AM »
Last time I checked Halfords were not selling the manufacturers recommended grade if Castrol Edge, it appears that they do a special version for turbocharged engines.
As mine is under an extended  warranty I have to stick with the local main dealer for another 12 months. Not sure if it will invalidate the hybrid battery warranty if I go outside the dealer network.
Offline Bradders
« Reply #5 on: May 24, 2026, 10:14:51 AM »
I also have an extended warranty on my Ford Kuga hybrid and so use the local main dealer but my understanding is that you can use a local independent  dealer as long as they are VAT registered and they  use genuine parts. When I last got a quote the price for the independent dealer using genuine parts was almost identical to Fords prices.
« Reply #6 on: May 26, 2026, 09:02:30 AM »
Make sure that any invoices from an independent garage quote the Registration and Vin number of the vehicle.
« Last Edit: May 27, 2026, 05:32:00 AM by Sesman »
Online Skoti
« Reply #7 on: May 26, 2026, 07:58:28 PM »
Please don't confuse recommended oil with manufacturers approved oil.
You must always use the latter if your vehicle is under warranty.
Skoti
1976 Honda CB750F1
