Author Topic: Why might my speedo be failing?  (Read 4802 times)
Offline TrickyMicky
Re: Why might my speedo be failing?
« Reply #15 on: June 19, 2026, 08:06:36 AM »
Maybe he has decided to stop pulling long 'wheelies' now that he's realised the speedo only works when the front wheel is turning???
« Reply #16 on: June 19, 2026, 08:44:55 AM »
If one breaks down near the wheel end, then the "floating" upper part can "snaggle" the still fixed end to give intermittent drive sometimes.
Had a once in a lifetime (well I expect it to be) headlight builb low beam go out at over 5000rpm on a Kawasaki triple, but on again below that, which turned out to be the bulb's filament detached from one of the main posts, to "wiggle" up out of contact as vibration increased.
Less vibration or static, and it remained on  ;D
Offline Athame57
« Reply #17 on: June 19, 2026, 12:05:55 PM »
Well actually that's what it has been doing today, working when it feels like it. Some meddling with the cable on the move ( bad idea!  :o ) can get it going again. I haven't pulled the cable out for inspection yet, I'm getting a bit cheeses off with it.
1978 CB400F2 named Elen.
Offline florence
« Reply #18 on: June 19, 2026, 03:24:49 PM »
I've been through so many speedometers it is beyond belief.  One wouldn't go above 50MPH, another developed an alarming squeal above 30MPH, another, the odometer stopped working and another was so vague, it waved + or - 20MPH whenever it felt like it.  I have consoled myself by coming to terms with the fact that speedometers are largely a cosmetic addition to the area above the headlight and now rarely look at it  ;D
Offline Athame57
« Reply #19 on: June 19, 2026, 04:19:53 PM »
Well, actually I've thought of giving up with it for a while too!  ;D
Offline Rayzerman
« Reply #20 on: June 20, 2026, 01:40:15 PM »
'72 CB350F, 2010 CBF1000FA
« Reply #21 on: June 20, 2026, 02:24:07 PM »
Undo the cable from speedo end, zip tie it so you can see it when riding, stick a tape "flag" to the cable end and then see if it turns all the time.
Separate the system into two parts, then look at each section on that analysis.
