Author Topic: Engine Painting Disaster - Help!  (Read 8530 times)
Offline Neilw
« on: June 13, 2026, 08:38:30 PM »
I have prepped the top end of the engine, primed with etch primer and given three light coats of VHT Silver. So far everything looks great, have also done the bottom end.
Today I loaded the top end bits into the oven and baked for 60 mins at 200 degrees as per instructions on the can.
When i opened the door, smoke poured out. I assume now from oil from the head, as I left the tappets in.
This has resulted in all the silver bits coming out a golden colour!  I've also got a small amount of blistering on some parts.
The bake seems to have worked as the paint is hard, but the colour is wrong!
How do I recover the situation? I plan to key the paint somehow ( ideas on how, please?) and apply a couple of fresh coats of paint? and then either bake again individually, but forget doing the head and let that cure on the bike when the engine gets hot.
Any other ideas or thoughts, please. It took a lot of work to get to this stage, and I'm gutted it hasn't come out as i had hoped.
I don't want to put the golden colour on the bike, as i have to touch up the blistered bit with silver, so it will look patchy!
Re: Engine Painting Disaster - Help!
« Reply #1 on: June 13, 2026, 09:29:52 PM »
I thought VHT paint is applied directly, is the etch primer heat resistant?
Not sure what you mean by leaving the Tappets in?
Have you melted the valve guide rubbers?
Offline Neilw
« Reply #2 on: June 13, 2026, 10:39:30 PM »
I had removed the valves, rubbers, etc., and it can have primer and is heat-resistant.
« Reply #3 on: June 13, 2026, 11:16:27 PM »
Reads as though oil or solvent has discoloured your paint?
Before I used our oven to bake my engine parts I used the Pyrotechnic Cleaning Setting on our oven to ensure there was no residual fat in my oven. Could be the bubbling be etch primer solvent not being fully dry? I also followed the temperature step guide for gradual increase of the baking temperature.
Offline Neilw
« Reply #4 on: June 14, 2026, 09:24:23 AM »
I think it's the oil in the rocker cover that has discoloured the paint. ( i meant rockers, not tappets) [ Guests cannot view attachments ]
I've given the breather cover a quick coat so you can see the difference between the two.
The only option I have is to give everything another coat and bake it separately. I guess a light rub with 400/88 grit should give a good key for the coat, unless anyone has a more informed idea of what I should do?
« Reply #5 on: June 14, 2026, 10:13:14 AM »
I did a similar thing in that my silver VHT paint went golden, I set the oven in centigrade not Fahrenheit.
« Reply #6 on: June 14, 2026, 03:21:52 PM »
The spots are caused by oil in the metal coming to the surface due to the heat. You need to start again I'm afraid. Use some sort of acid to get rid of the oil in the metal before repainting. And take the rockers out next time. That's just more oil vapour being released.
Offline exvalvesetdabbler
« Reply #7 on: June 14, 2026, 04:35:46 PM »
I used vht engine enamel many years ago, it was branded sperex back the before holts bought them out. Just branded VHT now and not to be confused with simoniz.
It didn't need a primer and it's stayed on aside from where I have been careless with spanners.
You need to wash with  paint thinners or acetone, bake it in the oven  at 100C, then solvent wash again. This will bring out any oil from the pores in the casting or corrosion pits which is probably what is causing some paint to lift.  When baking paint, dry overnight and then put it into a cold oven and slowly ramp up to 100C in stages then hold at that temp for half hour.
Regards
Dave
« Reply #8 on: June 14, 2026, 06:23:54 PM »
Sprex black was the go to for exhaustd back in the 70's
Offline Neilw
« Reply #9 on: June 15, 2026, 08:51:53 AM »
Thanks for all of your suggestions.  I can't face stripping the paint off and starting again, it's a huge job to do manually for the whole of the top end.
As it's only cosmetic, I think I'll lightly sand all the components and give them another coat or two of VHT. As for baking, i'll try the incremental increases and do them separately so I don't get any cross-contamination, i'll try a small test piece first to see if that works.
I know it's not the perfect solution and may come back with issues in the future, but I'm not planning on riding more than a few 100 miles a yr. Trust me what i have now is 1000% better than what was there before.
« Reply #10 on: June 15, 2026, 09:03:45 AM »
With my golden components I just gave them another coat and baked them again at lower temperatures, the crankcases were left to bake when the engine was running.
Offline Neilw
« Reply #11 on: June 15, 2026, 09:26:47 AM »
Yep, that's what I intend to do. Nice to know someone else has experienced similar issues.
Offline Neilw
« Reply #12 on: June 16, 2026, 08:42:52 AM »
I've just discovered that's exactly what I did!
« Reply #13 on: June 16, 2026, 03:04:15 PM »
Has anyone tried painting a small piece and baking it. Then soaking it in petrol to see how the paint reacts?
Neil, you have access to a Dremel or similar?
« Reply #14 on: June 16, 2026, 06:23:36 PM »
Many decades ago I did that with a car rocker cover using Silver Hanmmerite brush paint that was air dried for several weeks, finally oven baked at a low temperature.
It was oil, petrol & brake fluid resistant, it did go a tad yellowish after a couple of years. Not sure if they have improved the formula since then. It would crack on bulkheads if applied too thickly.
