Author Topic: Carbs got to come off again  (Read 5050 times)
Re: Carbs got to come off again
« Reply #15 on: June 21, 2026, 08:10:11 PM »
Use the bike regularly
With the sun we have now
No excuse
3 or 4 good rides a week
About 50 miles each
Should be able to get 2 rides per tank full
The running, vibration etc will help all the new parts to settle in
After all the hard work, you deserve to get out and enjoy
Offline Ken4004
« Reply #16 on: June 21, 2026, 09:45:41 PM »
Thats exactly what I had in mind for this week , another hundred miles and I’ll should have 500 miles on the clock since the rebuild so probably changed the oil and filter then back on the road.
Thanks everyone for your advice and support which is much appreciated.
Regards Ken
« Reply #17 on: June 22, 2026, 08:52:59 AM »
It should be much more responsive now, running fully on all four cylinders if all anomalies corrected.
These, smallest capacity four, have remarkable ability to mask quite significant combustion problems to those unaccustomed to them. Even if you are very close, adjusting the timing for example, they don't broadcast much in way of problems that may be internally troubling the clean running.
The engineering integrity of bottom end, barrels and head, in casting size and rigidity, keeps them very quite even with very poor running.  They soldier on remarkably with all sort of problems in firing.
Should be a lot more eager to spin easily now, then to give a better ride and heat management for the combustion.
Hopefully, it'll positively sing along now.
The oil will likely show a measure of fuel dilution after running on three cylinders intermittently, a change probably good from that aspect along with other running in consideration.
Offline Mikep328
« Reply #18 on: June 22, 2026, 09:07:46 AM »
Do a few runs to exercise that motor!  (the stuttering you will hear as the speed increases  is microphone wind noise, NOT engine misfiring) https://www.youtube.com/watch?v=OrGVaO3ogaE
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Offline Ken4004
« Reply #19 on: June 22, 2026, 10:21:14 AM »
Leave it in.  I do put about 3 spots of engine oil per 300 ml.. just drain it out in spring, connect up to the fuel tap, turn it on and it's fires up 3rd kick.
Regards
Dave
Thanks Dave , sounds like a great idea and very little cost, I was thinking of just draining the carbs but your right it’s better to have something in the carbs to stop any corrosion developing and to keep the seals wetted over a lay up.
