Author Topic: Rear brake return spring  (Read 2185 times)
Offline Athame57
« on: July 02, 2026, 12:12:13 PM »
Does anyone know of any images or diagrams to show how to fit the return spring at the pedal? I've only just discovered this bit is missing  ;D and now bought one, but it looks like it may be difficult.  ::)
1978 CB400F2 named Elen.
Re: Rear brake return spring
« Reply #1 on: July 02, 2026, 02:14:08 PM »
If I remember correctly you need to remove the whole brake lever pivot & shaft to fit the spring as it sits on the inside of the frame.
Others will advise if you can access it without removing the rear swing arm.
Offline exvalvesetdabbler
« Reply #2 on: July 02, 2026, 03:06:23 PM »
You might have to remove the swing arm to release the shaft
Regards
Dave
« Reply #3 on: July 02, 2026, 04:18:15 PM »
I think you have to remove swing arm to get the pivot shaft out, at very lesst remove wheel and shocks to get extreme movement of arm to get room for pivot shaft to come out
Offline Athame57
« Reply #4 on: July 02, 2026, 06:02:02 PM »
Thanks for this guys. As it's come to this I've booked my bike into a local workshop who are rather good. Too blooming hot for that much effort without my own garage!  :o
« Reply #5 on: July 02, 2026, 07:06:20 PM »
Can I suggest you also consider sliding some carb overflow tubing over the metal tang that goes against the frame, it protects the frame paint from damage.
Offline Athame57
« Reply #6 on: July 02, 2026, 10:17:48 PM »
You can.  :) I have some in the house.  ;)
« Reply #7 on: July 03, 2026, 07:00:17 PM »
100% in agreement with Ken on the rubber tubing, that spring really does dig into the paint.
Before you remove the brake pedal George make sure you can see the dot mark on the shaft and the corresponding one on the brake pedal. If you can't see one mark it yourself otherwise you'll be taking the pedal on and off trying to find it's best position for your foot!
Offline Athame57
« Reply #8 on: July 03, 2026, 08:29:18 PM »
I behaved like an idle sod and let the professionals do it again, the job looked difficult without my own garage to do it in. Snag is I forgot to take that piece of tubing with me. Oh well, if I get problem I'll use the artists brush....  ;)
