Author Topic: CB750K6 Headlight Mainbeam Button Spring  (Read 1104 times)
Offline Martin6
« on: July 07, 2026, 10:46:54 AM »
Hi all. My K6 is still going strong after much work and re-furb 3 years ago.
I had a failure of the horn button, on the left side handlebar switchgear. A soldered terminal had dried up, which I fixed. However, when putting it back together, the tiny spring on the headlight flasher button flew off, never to be seen again.
I have cobbled something together using a spring from a ballpoint pen, but it is too large (diameter) and doesn't stay put. By any chance, does anyone have a spare? If not, could anyone recommend a source for a suitable replacement?
Many thanks,
Martin
Re: CB750K6 Headlight Mainbeam Button Spring
« Reply #1 on: July 07, 2026, 12:40:40 PM »
There was a seperate part number for the spring on the starter button on earlier bikes, look at a 72 500. That might fit and last time i looked was still available
Offline Martin6
« Reply #2 on: July 07, 2026, 12:47:09 PM »
Thanks Bryan. I have searched on that part #. In Google and David Silver, both come up with a rotary blade.
Offline ST1100
STOC #637
« Reply #4 on: July 07, 2026, 03:38:57 PM »
Dave silver says order in so should be available from any Honda dealer but is £5 plus drat so expensive if it dont work.
Same part on lots of 70's Hondas so somebody must have one, me yes probably but has anybody seen my garage!!!!!
Offline Martin6
« Reply #5 on: July 07, 2026, 04:15:21 PM »
Thank you both, I still can't get to it on the David Silver website, I will ring them.
Regards, Martin
