Author Topic: Valve lapping  (Read 1000 times)
Offline Craizeehair
Valve lapping
« on: July 08, 2026, 05:25:43 PM »
I’ve been watching some Allen Millyard videos recently and saw that after he lapped the valves on his Kawasaki Z1 Super Six, he applied grease to the valve seat and stem before refitting.
I will be lapping the valves on my CB350K2 in the not too distant and wondered if this this a thing, I am a novice at these things but hadn’t seen anyone doing or recommending it before?
Re: Valve lapping
« Reply #1 on: July 08, 2026, 06:12:24 PM »
Likely because the materials rust easily if left for long, especially where they've been lapped as no surface "polishing" through running/use will have been left to help mitigate any moisture that could accumulate.
Less likely in this current weather though  ;D
The grease will just dissappear when it's started and running. Sounds a reasonable precaution, especially if head building precedes much time sitting while waiting for tge final assembly.
Offline Craizeehair
Re: Valve lapping
« Reply #2 on: July 08, 2026, 06:29:57 PM »
Makes sense, thank you
