Author Topic: Stripped thread  (Read 4169 times)
Offline ted_paper
Stripped thread
« on: July 23, 2026, 05:48:58 PM »
When tightening the front wheel axle clamp bolt nuts, one of them is refusing to tighten and just spins. Having tried different nuts I assume that the thread on the stud is stripped and needs re-cutting.
This would be my first attempt at using a tap-and-die kit and would appreciate any advice as to what size die I would need and can this be done without removing the leg?
Re: Stripped thread
« Reply #1 on: July 23, 2026, 07:29:35 PM »
DO NOT try to rethread the stud, unscrew it and replace it
Offline ted_paper
Re: Stripped thread
« Reply #2 on: July 23, 2026, 07:45:24 PM »
Is there a reason for not rethreading the stud?
Re: Stripped thread
« Reply #3 on: July 23, 2026, 08:24:56 PM »
Usually, a stripped stud (male component) no sniggering the back  :D will have lost the outer diameter that forms the thread peaks securely. Thst leaving nothing to cut effectively.
Recutting would ordinarily require going down in thread size, for example 10mm to 8mm which would then make the stud undersized for it's designed stress loading.
Good quality "mole" grips tightly applied, or one of those proprietary stud extractor tools will just unscrew this one, to then let you install  new one.
Offline ted_paper
Re: Stripped thread
« Reply #4 on: July 23, 2026, 10:33:08 PM »
Thanks for advice.
New stud it is. :)
Offline Athame57
Re: Stripped thread
« Reply #5 on: July 23, 2026, 11:23:10 PM »
I can't help comparing this to my non standard exhaust studs. The mechanic at the workshop I was using at the time advised me not to try and have them removed lest they snap off, which would be very complicated. I have a new set of studs gathering dust just now.  You mentioned 'proprietary stud extractor tools' which I've never heard of. Maybe the better workshop I rely on now could do the job or is it still probably  too dodgey? :-\
1978 CB400F2 named Elen.
Re: Stripped thread
« Reply #6 on: July 24, 2026, 02:39:49 PM »
I feel tbe first guy, and his advice, was from decent experience and quite wise. These are notoriously fraught for weakening, corrosion and often well "entrenched " in their little home position.
They can snap easily, and if functional along with being secure, you'd not offer to tackle them for no good reason.
The fork stud having much more important structural load, usually they are generally a bit oily too, makes them far more approachable to remove, also being next metric size up (from memory) have a larger core diameter and so significantly reduced risk of snapping when working on them.
The exhaust , if snapped, a right pain to work on, with little option but to drill out, giving you the chance to understand what fraught means in engineering terms  :)  ultimate failure often leading to head off, boring out properly on a milling machine (you might as well do them all while at it) to then fit a stepped stud or insert before further use.
I'd leave them be, assemble with generous amount of copper grease unless you've a concours winning example.
Offline Athame57
Re: Stripped thread
« Reply #7 on: July 24, 2026, 08:03:18 PM »
I think these new studs I have will be gathering more dust then. If the head comes of eventually I'll consider the big job of fitting them so as to avoid a broken stud down the road.
Offline Mikep328
Re: Stripped thread
« Reply #8 on: July 25, 2026, 06:49:09 AM »
There are two commons schools of thought re mechanical work - one is the "While you are in there" school which advocates replacing any/everything that can be accessed while you are working on some component.
And there is the "If it aint broke, don't fix it" school.
In many years of working on cars/boats/motorcycles (vintage and otherwise) I have personally found the second to be the better choice.  As the mechanic who taught me a lot about such work when I was teen often said, "Sometimes the best thing to do is Leave it the F^$% alone!!!!"
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Re: Stripped thread
« Reply #9 on: July 25, 2026, 09:26:59 AM »
That comment is good EXCEPT when there are known problems that occur like 500 primary chain and dampers if the cases are split but not shells just because its apart, rarely wear and damned pricey
Offline Mikep328
Re: Stripped thread
« Reply #10 on: July 25, 2026, 09:37:44 AM »
"That comment is good EXCEPT when there are known problems"
Totally agree!!!
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
Offline Otis
Re: Stripped thread
« Reply #11 on: July 26, 2026, 05:21:48 PM »
I agree but is there not also a danger that the internal female thread could be slightly torn as well?
Graham
1972 Honda CB350F
1997 Ducati ST2
Re: Stripped thread
« Reply #12 on: July 26, 2026, 06:07:48 PM »
Not seen one yet and as its a standard 8mm it could be helicoiled anyway
Offline ted_paper
Re: Stripped thread
« Reply #13 on: July 27, 2026, 01:07:36 PM »
Old stud removed and new one ordered.
Just thought I might as well replace the nut as well but these are coming up at £3 ish for one - are they not just a 8mm nut or is it a special Honda thread?
Re: Stripped thread
« Reply #14 on: July 27, 2026, 01:41:05 PM »
Ordinarily std thread on there, but honda usually use a 12mm hex size instead of a std issue 13mm for this sized drive nut/bolt fitment.
You're right, high cost for single item, but ultimately the correct one is desirable in this case I feel.
