Author Topic: Cam Tensioner Rod, Springs and Bolt  (Read 4868 times)
Re: Cam Tensioner Rod, Springs and Bolt
« Reply #15 on: August 17, 2026, 02:30:05 PM »
Very well done, perhaps you should take over making kits and sellingbthem!
« Reply #16 on: August 17, 2026, 02:50:47 PM »
Well done, another engine saved :)
Offline Rozabikes Tim
« Reply #17 on: August 17, 2026, 04:00:26 PM »
Good work.
Should  be known as a "proper debodging"!!
Sent from my Pixel 5 using Tapatalk
Offline Wrenchpuller
« Reply #18 on: August 18, 2026, 07:42:00 PM »
Thanks all!
The unf threads were pretty poor so the insert doesnt go all the way down the shaft, i added a few mils of recess after the photo was took so the bolt would sit further in like original, but didnt want to go too far as i would loose too much thread.
This unfortunately means the bolt doesnt actually reach the push rod, but that's ok as I managed to get one of the TTR400 manual adjuster bolts, so this will remain backed off and locked. Suppose I could make a longer version of hondas bolt if it came to it!
« Last Edit: August 18, 2026, 07:47:05 PM by Wrenchpuller »
« Reply #19 on: August 20, 2026, 05:41:38 PM »
Never mind!
I must've had my eyes closed when I checked it the first time!
It does reach the push rod and locks it too like it should lol
Thanks all
