Author Topic: Pamco ignition  (Read 1569 times)
Offline redtractor
Pamco ignition
« on: August 04, 2026, 05:16:09 PM »
Hi, Does anyone know if Dyna coils will work with Pamco ignition, thanks, Sarah.
Re: Pamco ignition
« Reply #1 on: August 04, 2026, 06:18:57 PM »
Do you know the specification of your coils (Impedance/resistance) rather than the brand.
As electronic ignition is meant to take the place of points that should work with most coils if it's for a 750 I would have thought you just need the right resistance Dyna coil.
« Last Edit: August 04, 2026, 07:39:46 PM by McCabe-Thiele (Ted) »
Offline Skoti
Re: Pamco ignition
« Reply #2 on: August 04, 2026, 08:02:40 PM »
If Dyna coils are OK to replace stock coils then they will be fine.
https://www.dynaonline.com/dyna-igntion-coils-set-dual-output-3ohm-dual-plug-single-fire-1/?srsltid=AfmBOoqNZzKdbwfoz73FRCf8FNFe5GDMFQW3IYmO9cuVA7DeWtOtjUHg
https://4into1.com/pamco-instructions-honda-cb350f-cb400f-cb500k-cb550-cb750/?srsltid=AfmBOopBt_ch93BkgbGIlCxfRx-xPxtuDNTFi22yQevAKXVUlJIeIsWj
Technical Information:
Technology: Hall effect sensor, IGBT coil driver
Dwell: Fixed, 120 degrees
Coil primary resistance: 2.5 to 4.5 Ohms, dual output. (Stock coils may be re-used)
Operating voltage: 6 to 18 VDC
Operating current: 13 ma
Operating Temperature: -40 to +150C (-40 to 302F)
Spark Advance: Standard, centrifugal
Simple installation: Battery, ground and coils. No external box of tricks.
Plate milled from high quality aluminum.
Rotor with two magnets made from a solid billet of aluminum on a CNC machine.
« Last Edit: August 04, 2026, 08:17:06 PM by Skoti »
Skoti
1976 Honda CB750F1
Offline redtractor
Re: Pamco ignition
« Reply #3 on: August 08, 2026, 07:57:03 PM »
Sounds like they will work, thanks Guys
Re: Pamco ignition
« Reply #4 on: August 08, 2026, 08:46:45 PM »
Iirc Dyna Coils have the resistance moulded into the casing.
