Author Topic: Twin Carb 500/4?  (Read 3493 times)
Twin Carb 500/4?
« on: August 06, 2026, 06:29:40 AM »
https://ebay.io/m/B0Atpo
Anyone we know?
Never heard of a twin carb conversion.
Why would you do that?
Re: Twin Carb 500/4?
« Reply #1 on: August 06, 2026, 10:38:59 AM »
Replacing the original carbs on a CB550 by two VM34 Mikuni's is quite a popular mod in the US. This is just one vid, but there are more. https://www.youtube.com/watch?v=2Sm8APjP9G4&t=360s
« Last Edit: August 06, 2026, 10:41:00 AM by deltarider »
Offline florence
« Reply #2 on: August 06, 2026, 12:48:56 PM »
That feels wrong to me.
Online McCabe-Thiele (Ted)
« Reply #3 on: August 06, 2026, 12:58:06 PM »
Twin carbs on 4 cylinder engines was the norm at one time.
« Reply #4 on: August 06, 2026, 02:33:49 PM »
Well... if it was is about a CB550K3 or -K4 with these PD carbs... The boss of a motorcycle business nearby had a CB550K3 he still hadn't found the time to work on. He had in mind to replace the carbs by... fuel injection. LOL
« Reply #5 on: August 08, 2026, 09:46:34 AM »
I would guess that's a lot of work making or modifying inlet manifolds, air box, cables etc for little reward but.....I do like the ingenuity of it so hats off to whoever did it for making something a little bit different.
« Reply #6 on: August 08, 2026, 11:36:59 AM »
Yeah, that boss of the motorcycle business eventually got rid of his CB550K3 because he never had the time to do it. In the past I've known a guy who had modified his CB500 to a 4-valve per cylinder one and had raced it.
Offline badger_eng
« Reply #7 on: August 23, 2026, 11:50:07 AM »
The bike is fitted with ''Murrays Carbs'', he's a bit of a legend on the Honda CX500 circles / forums. US based guy / outfit.
https://murrayscarbs.com/product/honda-cb550-carburetor-kit
I fitted his carbs to my CX500 build. Albeit it was two carbs for 2 cylinders. Ordered them on a Thursday night and the arrived Saturday lunch from the US. (Quicker than some of my local takeaways tbh!)
They are very thirsty items but do offer a small power increase. The CDI unit had failed on the CX so I replaced it with a Rae-San unit from Australia, this unit had various configurable settings for ignition advance via dip switches and one was basically to run with Murrays Carbs.
Most of his 4 cylinder offerings use a pair of Mikunis matched to shared manifolds. I cant comment on these but his CX500 VM34's were pretty good.
Current:-
Suzuki GSX-S1000GX+ - 2026
Suzuki GT500A Cafe style - 1976
https://www.kettleclinic.co.uk/kcforum/viewtopic.php?t=14273
Honda CB550K - 1977 (Winter 2026/27 project)
Offline TrickyMicky
« Reply #8 on: August 23, 2026, 08:32:26 PM »
Firstly, I admit that I did not see or hear much of the video, But I thought it unusual to have cylinders 1 & 2 sharing a carb, likewise 3 with 4.  Earlier twin cylinder Hondas only shared a carb if they had a 360 degree crank because the intake and exhaust pulses were evenly spaced giving smoother breathing. Bikes like the CB72/77 and the later CB250 K series had twin carbs because they were fitted with 180 degree cranks which give uneven pulses.  The way the video shows the carb fitting means that each carb is supplying a pair of cylinders which are 180 degrees apart.  Many years ago Mick Hand sprinted a 250 supercharged Honda which was catalogued as a CB72, but it had a C72 crank fitted to obtain the regular intake pulses.
