Author Topic: 550 tank flap clip  (Read 2168 times)
Offline bbrian66
550 tank flap clip
« on: August 16, 2026, 03:54:40 PM »
Hi Guys
Does anyone know where I can find the wire spring clip that holds the tank filler flap down? I can't find one anywhere so don't know if I'm looking in the wrong place,  or wether they're just not available.
If not available,  does anyone have suggestions as to what i can do?
Thanks!
Re: 550 tank flap clip
« Reply #1 on: August 16, 2026, 03:57:46 PM »
Make one. You just need the right type of wire.
Offline bbrian66
« Reply #2 on: August 16, 2026, 04:20:07 PM »
Yes that did seem to be an option. Do you happen to know the dia of the wire i'd need?
« Reply #3 on: August 16, 2026, 04:38:20 PM »
I’d say 1 or 1.5mm should do it. About the thickness of a spark plug helicoil if you have one. Might be able to unwind one of those, shape it and then anneal it to keep its shape.
Offline DomP
« Reply #4 on: August 17, 2026, 04:54:08 PM »
I could measure the thickness of one of mine for you but I'd guess 1-1.2mm
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline bbrian66
« Reply #5 on: August 20, 2026, 03:36:26 PM »
Thanks DomP - I've bought a couple of short lengths of 1.0mm and 1.5mm from fleabay - I'll see what I make of these when they turn up.
