Author Topic: Exhausting mystery.  (Read 3143 times)
Offline exvalvesetdabbler
Re: Exhausting mystery.
« Reply #15 on: August 16, 2026, 10:29:27 PM »
Save that thought for those that pretend to run our country :)
« Last Edit: August 16, 2026, 10:32:12 PM by exvalvesetdabbler »
Offline Ken4004
« Reply #16 on: August 17, 2026, 08:35:53 AM »
Hi Athames57
If your interested I have one of these brackets spare, I was going to put it on EBay but have not got around to it yet.
Please see photos attached regards Ken
« Last Edit: August 17, 2026, 08:38:29 AM by Ken4004 »
Offline Athame57
« Reply #17 on: August 17, 2026, 12:19:22 PM »
Hi Ken
PM'd you!
1978 CB400F2 named Elen.
« Reply #18 on: August 18, 2026, 03:55:13 PM »
If you fit the OE bracket George are you going to fit the OE packer/seal in the silencer to collector box? I can see the Thuruxton silencer you currently have fitted is straight, fitting the OE bracket may angle it slightly upwards opening up the joint between the silencer and the collector box and this will require a packer gasket otherwise the joint could end up blowing.
You can get the packer on eBay a lot cheaper than Honda OEM.
Offline Athame57
« Reply #19 on: August 18, 2026, 04:00:23 PM »
Yes Dave. I have actually got that item right here, erroneously bought when I got the new downtubes and collector box with it's fittings. The clamp I have also as the Thruxton one is smaller.
