Author Topic: OOps, always worrying!  (Read 4773 times)
Re: OOps, always worrying!
« Reply #15 on: August 20, 2026, 06:35:44 PM »
The regulator has 2 bolts holding it onto the plate, both are M6 x 16mm. Measure the bolt and that will mean we can tell you exactly where it's come from.
« Reply #16 on: August 20, 2026, 06:50:35 PM »
I'm pretty sure my regulator has two bolts securing it.
One at the top, one at the bottom.
Offline exvalvesetdabbler
« Reply #17 on: August 20, 2026, 06:54:49 PM »
Just add the bolt to your jam jar of other surplus fasteners.  One day it will come in handy.
Regards
Dave
Offline Otis
« Reply #18 on: August 20, 2026, 08:30:04 PM »
Looking at the size of that washer, could it be one of those bolts that have a rubber cushion beneath, and do you remember how many of those you fitted back?
If you go an inch up from number 21 and go right you will see a hooked bracket that holds the regulator. There is no second fixing for the regulator on my bike
Graham
1972 Honda CB350F
1997 Ducati ST2
Offline Athame57
« Reply #19 on: August 20, 2026, 08:45:36 PM »
Are you sure you aren't responding to Oddjob?  ;)
1978 CB400F2 named Elen.
« Reply #20 on: August 20, 2026, 09:03:41 PM »
I am sure the regulator should be on two bolts, the rubber will be solenoid or flasher relay
« Reply #21 on: August 20, 2026, 09:25:50 PM »
It's a long shot, when you say your regulator is held on with one bolt, you do mean the regulator, not the rectifier?
Offline Otis
« Reply #22 on: August 20, 2026, 09:39:05 PM »
I don't believe there is a seperate rectifier? Aren't the regulatorss and the rectifiers combined?
Graham
1972 Honda CB350F
1997 Ducati ST2
« Reply #23 on: August 20, 2026, 09:39:23 PM »
Looking at the pictured posted, it looks like a combined reg rec unit so the fixing won't be standard unless there's an adapter bracket.
Regards
Dave
« Reply #24 on: August 20, 2026, 09:42:59 PM »
Here is the original regulator, bolted to the air filter box. [ Guests cannot view attachments ]
Regards
Dave
« Reply #25 on: August 20, 2026, 09:50:07 PM »
Ah ha. Looks like someone has relocated the OEM rectifier. That lump with fins looked like an aftermarket combined unit.  I can see the original regulator in the most recent image.
The original   rectifier on the 400 was on the other side
Regards
Dave
« Last Edit: August 20, 2026, 09:57:35 PM by exvalvesetdabbler »
« Reply #26 on: August 20, 2026, 11:31:27 PM »
It might not be an issue, I thought the rectifier was mounted where it was originally to aid air flow/cooling.
Offline Otis
« Reply #27 on: August 21, 2026, 10:19:12 AM »
Here is the original regulator, bolted to the air filter box. (Attachment Link)
Regards
Dave
OK, mystery solved.
I'm a bit confused about regulators, rectifiers and combined units but if the unit with the white strip containing green and black rectangles is the original regulator then that is what I have and the bolt fitted the upper fixing. It was concealed behind a part of the harness so I missed it. I must have started to remove this unit and then realised it didn't need to come out.
Anyway, thanks to all for the help and guidance which as always, is educational.
Graham
1972 Honda CB350F
1997 Ducati ST2
« Reply #28 on: August 21, 2026, 01:17:02 PM »
Regards
Dave
OK, mystery solved.
If a combined unit has been fitted,  the one part replaces the original Rectifier and Regulator.
Yours has what looks like the original Regulator, it's held in place by the top and bottom bolts via rubber mounts fitted to the regulator.
The Rectifier is the unit with the alloy fins in your photo.
It might be worth checking if you have the lug on the right side of your frame where the original Rectifier is bolted in place by one bolt.
Seems unusual that yours is fitted where it is,  makes me wonder if the wiring lead is too short to mount it in the correct place. Might be worth investigating a possible move to a cooler position on the right side of the frame.
