Author Topic: Dismantling oil filter bolt  (Read 3958 times)
Offline badger_eng
Re: Dismantling oil filter bolt
« Reply #15 on: August 26, 2026, 07:34:06 PM »
The spring sits on the roll pin, it pushes against a small metal cup, with the spring sitting inside the cup. The cup blocks holes in the filter bolt, however if the filter collapses or blocks enough to stop oil flow the pressure of the oil pushes the cup down against the spring pressure and that means the holes it was blocking are now exposed. The oil uses these holes to bypass the filter so stopping the engine from seizing. Get a small sharply bent piece of metal and push down on the cup, it should move, if it doesn’t you have a problem and you’ll need to dismantle the bolt to free it off.
Thanks Oddjob. A better explanation than my simplistic version :-)
Current:-
Suzuki GSX-S1000GX+ - 2026
Suzuki GT500A Cafe style - 1976
https://www.kettleclinic.co.uk/kcforum/viewtopic.php?t=14273
Honda CB550K - 1977 (Winter 2026/27 project)
Offline Athame57
« Reply #16 on: August 26, 2026, 08:42:32 PM »
Thanks for this Odjob, I'll be doing this at my next oil change that is coming up soon.  ;)
1978 CB400F2 named Elen.
« Reply #17 on: August 26, 2026, 11:45:40 PM »
I would suggest checking the oil pressure relief valve on the oil pump at the same time George. Not as easy to check though I’m afraid.
Offline Athame57
« Reply #18 on: August 27, 2026, 12:05:46 AM »
I'm soon to have the seals on my oil pump changed ( got them from Julie) I'll get it done then. Thanx mate!  ;D
« Last Edit: August 27, 2026, 12:07:22 AM by Athame57 »
