Author Topic: Superdream Front & Rear axle nuts - prices  (Read 711 times)
Offline Skoti
Re: Superdream Front & Rear axle nuts - prices
« Reply #15 on: September 20, 2026, 04:41:27 PM »
Item not listed to fit the CB400NA presumably as it was not the original part.
It might fit, no flange o/d shown.
Also available aftermarket and fits Yamaha and Aprilia too.
https://www.wemoto.com/parts/ah5489?srsltid=AU7gw4WIJMFmR4wEcabNxp1iY_o3W439FYAPUlGrT9IUBtjenu4fAzgF
Flange diameter 26mm
Height 14mm
Your local Honda dealer may have stock so you could compare it with your original nut, and save you postage if it's suitable.
Good luck
« Last Edit: September 21, 2026, 12:35:47 PM by Skoti »
Skoti
1976 Honda CB750F1
