Author Topic: Stubborn grips  (Read 760 times)
Offline Athame57
Stubborn grips
« on: October 10, 2026, 08:29:12 PM »
I'm soon to change for the first time in eight years my handle bar grips. I remember the hell of getting them on then, anyone know an easy way?
1978 CB400F2 named Elen.
Re: Stubborn grips
« Reply #1 on: October 10, 2026, 08:33:44 PM »
If you're fitting the OEM ones like I stock, they should be pretty easy to fit on George.
Re: Stubborn grips
« Reply #2 on: October 10, 2026, 09:10:33 PM »
Clean bar and throttle grip with Naptha (tin of lighter fluid) and let dry, then slosh a little inside grip and straight on with in one surprise movement  :)
Usually not bad like that, and don't slip afterward.
Offline Athame57
Re: Stubborn grips
« Reply #3 on: October 10, 2026, 10:00:18 PM »
Damn, I'm too late for that Julie, unless things go pear shaped with the ones I've ordered.
Re: Stubborn grips
« Reply #4 on: October 10, 2026, 10:19:42 PM »
I used Wendy's Hair spray to make sure they stay in place, particularly for the throttle side.
I used Meths to clean the bars / throttle tube.
Offline Athame57
Re: Stubborn grips
« Reply #5 on: October 11, 2026, 01:00:07 AM »
Hi Ted, what to say? I have no Wendy's in the house. Meths, well I quit drinking that years ago!  ;D
Offline neat street
Re: Stubborn grips
« Reply #6 on: October 11, 2026, 08:04:44 AM »
soak in hot soapy water with a little washing up liquid on the bar, once dry they dont move.
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Offline badger_eng
Re: Stubborn grips
« Reply #7 on: October 11, 2026, 09:56:43 AM »
Gel hand sanitizer works for me (from our much loved COVID days)
Wipe it on the bar or inside the grip, they slide on easy then as the alcohol evaporates, the residual tack will keep the grips firmly in place.
Current:-
Suzuki GSX-S1000GX+ - 2026
Suzuki GT500A Cafe style - 1976
https://www.kettleclinic.co.uk/kcforum/viewtopic.php?t=14273
Honda CB550K - 1977 (Winter 2026/27 project)
Offline Athame57
Re: Stubborn grips
« Reply #8 on: October 11, 2026, 10:41:57 AM »
That sounds like the cleanest option, I might take you up on it!  ;D
Offline Ken4004
Re: Stubborn grips
« Reply #9 on: October 11, 2026, 11:57:26 AM »
I used the tie wrap method , so put several medium tie wraps between handle bar and hand grips which seemed to work very well for me.
Offline Ken4004
Re: Stubborn grips
« Reply #10 on: October 11, 2026, 11:59:49 AM »
https://youtube.com/shorts/uvCpcT4z8Tk?is=85Fn2Pv6-pYZMLXU
This is the tie wrap method I used and thought it was very straight forward.
Offline Athame57
Re: Stubborn grips
« Reply #11 on: October 11, 2026, 05:53:06 PM »
Nice hack, what to say but WOW! ;D
Re: Stubborn grips
« Reply #12 on: October 11, 2026, 06:44:25 PM »
That's quite a nifty trick. Can't see how it would work on the OEM CB SOHC/4 grips as they are fully closed at the end.
Re: Stubborn grips
« Reply #13 on: October 11, 2026, 07:37:17 PM »
Unless the video is Ai faked.
Re: Stubborn grips
« Reply #14 on: October 11, 2026, 07:41:39 PM »
I don't think so Ted, they look like the type of grips where you have bar end weights fitted.
