Author Topic: CB550 Tuning Advice  (Read 1708 times)
Offline Neilw
Re: CB550 Tuning Advice
« Reply #60 on: October 20, 2026, 08:18:36 AM »
Could the rubber bits be coming from the rubber sealing washer inside the petcock?
On the auxiliary tank fuel supply ?
I don't know what config is there, but running some fuel i to clear container should show anything not desirable.
I'm using a clear auxiliary tank with a clear pipe.
« Reply #61 on: October 20, 2026, 08:39:06 AM »
I was wondering if scottly was questioning if there was a petcock on the auxiliary tank, and if that had any parts in it with this potential.
I know some have a metal petcock as others have a simple plastic clamp external to the feed pipe.
Offline Neilw
« Reply #62 on: October 20, 2026, 09:44:50 AM »
Ah, yes, sorry, yes it has a petcock - i'll check that too!
« Reply #63 on: October 20, 2026, 10:02:21 AM »
I have an online filter on my Auxiliary tank, just in case of contamination from the petrol can, my cans all have rubber type seals on the caps.
Must be very frustrating.
« Reply #64 on: October 20, 2026, 10:51:03 AM »
In general: do not position an auxiliary tank much higher than the bike's own tank. This to prevent floatvalves opening and as a consequence carbs overflowing.
Offline Neilw
« Reply #65 on: October 20, 2026, 11:06:26 AM »
Got that; tried to keep the differential the same.
Got the float heights about right; fuel is settling a few mm below where the float bowl joins the body of the carb.
I've double-checked the drain screws for debris and cleaned them with carb cleaner and compressed air.
Also flushed the carbs through with petrol, and for the most part the fuel is clear. I flushed about a litre of petrol through; there may be two really tiny black bits, which you can barely see with the naked eye. It's as good as I can get it, so accept that perfect doesn't exist, and there will be natural contaminants in fuel that I can't do anything about, but I'm not going to put a filter in at this stage, as the bike as standard didn't have one. Might be a different story when I get to the Tank.
OK, back to bench syncing and sticking them on the bike.
« Reply #66 on: October 20, 2026, 11:43:51 AM »
It's ironic, when I first started my 500 it ran great, I had treated myself to a new auxillary petrol tank that came with a T piece and pipe.
A few days later just before I was going to fit the tank I started it up again, iirc the pipe had swollen and was a bit sticky to the touch. When I started the engine it ran like a camel and started flooding.
There were black bits off the inside of the pipe in all the bowls. I was so gutted I walked away for a few weeks before I could find the motivation to take the carbs off to strip & clean them again.
That's why I added the Aeroline filters, yes they are not original, they are pretty well hidden under the carbs, you have to look to notice them. I just figured an old bike needs some extra help, probably ott, peace of mind.
When you eventually fix the problem anf post the cause/fix it will be satisfying, sharing here helps us all.
« Last Edit: October 20, 2026, 11:46:22 AM by McCabe-Thiele (Ted) »
Offline badger_eng
« Reply #67 on: October 20, 2026, 12:11:24 PM »
From my experience of using the auxiliary tanks that are cheap as chips from all the usual places, the tubing that comes with them is very poor quality. I have my doubts that the tubing is even fuel compatible.
After using the cheap aux tank for my first resto 5 years ago, the tubing had perished within a year.
I replaced with cheap clear polyflo style tubing. Whilst this quickly goes hard / brittle, it does not shed its guts into the carbs like the ‘’rubber’’ variants do.
Current:-
Suzuki GSX-S1000GX+ - 2026
Suzuki GT500A Cafe style - 1976
https://www.kettleclinic.co.uk/kcforum/viewtopic.php?t=14273
Honda CB550K - 1977 (Winter 2026/27 project)
« Reply #68 on: October 20, 2026, 04:13:59 PM »
It's another advantage of my simple method for checking the fuel levels: by draining the bowls you'll detect any contaminants rightaway. http://forums.sohc4.net/index.php/topic,185754.msg2151647.html#msg2151647.
« Last Edit: October 20, 2026, 04:19:54 PM by deltarider »
Offline scottly
« Reply #69 on: October 20, 2026, 06:33:48 PM »
Sorry, I missed that an auxiliary tank was being used. I was thinking of the petcock in the stock tank. :-[
Seeley SH7-521 owned since 1979
Online Oddjob
« Reply #70 on: October 20, 2026, 08:50:26 PM »
I think it was a good suggestion either way. We seem to forget the tap uses not only the doughnut seal but orings as well. All could be failing after this amount of time. I’ve already upgraded my 500 petrol tap to all Viton fittings.
Whose to say the next failure could well be the fuel tank cap seal.
