CB500 Four wiring fault
Topic: CB500 Four wiring fault (Read 519 times)
Plammiman
Newbie
October 31, 2026, 04:42:31 PM »
Hi I have a 1975 original UK CB500 four where I do not have a working brake light from the rear brake. Front works normally. I have gone through the visible wiring and checked it out with my tester. I get 12 volts to the rear stop light with no load, ie no bulb fitted. When I install the bulb if I check for voltage on the black wire at the rear brake switch connector next to the battery I get 12 volts but as soon as I press the brake lever the voltage drops to zero. If I bridge the switch connector to remove the switch same thing zero volts once I connect the wires. Earths have been cleaned and are good. My question is where can I trace the black wire back too to find what must be a bad joint. I have been through the headlight and can’t find anything there. If I apply a power supply to the green and yellow at the back brake switch connection the brake light works.
Any suggestions welcomed
McCabe-Thiele (Ted)
Re: CB500 Four wiring fault
October 31, 2026, 08:10:26 PM »
Not sure if this file will upload, coloured wiring diagram for 400, might help with colours for your 500 brake lamp..
It appears you have power to the rear brake switch, have you tried a temporary wire between the brake switch to the rear lamp, obviously disconnecting the existing connection on the brake lamp? There is a small loom between the rear lamp where it connects near the front of the seat iirc.
Last Edit: October 31, 2026, 08:26:13 PM by McCabe-Thiele (Ted)
Link to my full restoration
Plammiman
Newbie
October 31, 2026, 11:09:18 PM »
Thanks for the coloured diagram it makes life easier to view the wiring. I have powered the stop light from the rear brake light loom connection with an alternative wire and it works. The problem with schematics is they show the wiring diagrammatically however the physical wiring layup is different. What I want to find is the other end of the black wire from the rear brake switch connection. Theres going to be a bad joint somewhere and they don’t usually join the wires in the wrapped part of the main looms, but I could be wrong. I have a spare connector above the coils which seems standard on the wiring diagram. It has power to it but also shows an inconsistent voltage like I see at the brake switch connection. Just to add the voltage at the brake switch can vary from a shade under the battery voltage reading and down to around 9 volts symptomatic of what’s going on. Everything else works on the bike🤷🏻♂️
November 01, 2026, 04:38:15 AM »
The black wires have several places inside the loom where two or more are crimped together,.
Finding the bad one means undoing the loom progresively till you find the bad joit, personally i wouldrun a new wire from the black at the regulator to the brakelight switch
deltarider
My kingdom for a turkey!
November 01, 2026, 06:47:10 AM »
You don't have to. The appropiate wiring diagram will show you. Is yours a CB500K1-E? Usually it has two one or two black females free in the headlamp bucket. In this case voltages are best checked for enough juice with the engine running. p.'93' in:
https://www.honda4fun.com/dwnload/Owners-Manual/CB500-K1-Owners-Manual.pdf
McCabe-Thiele (Ted)
November 01, 2026, 08:22:59 AM »
My 500 has the one main fuse iirc, I did not replace the loom, I did replace most of the block connectors (Cojaycat)
There is a sub loom in the left side cover area that was in poor condition, with very poor connections. I replaced a few badly corroded spade terminals that were inside the blocks.
The sub loom was a mess, I managed to source a pricey replacement.
Plammiman
Newbie
November 01, 2026, 09:15:40 AM »
Thanks for the info and suggestions and the Honda book is a great piece of info. For now I will run a new wire as that’s the easiest option. I’m still figuring out whether to leave this as an oily rag bike as it all original including the pipes. If I end up with a full refurb then I might dig into the loom and find the offending joint
McCabe-Thiele (Ted)
November 01, 2026, 09:38:41 AM »
I kept the main wiring loom that was on my bike, I did unwrap a lot of the loom, the joints were good.
I can't remember where the joints were now, I replaced the joint insulation as a precaution.
deltarider
November 01, 2026, 02:59:32 PM »
So far I didn't have to replace any of the 1976 wires/looms. When not on the road, bike is parked in my garage. IMO people tend to replace wirings/looms too hastily. When you measures voltages with the engine running > 1600 RPM, the picture is a lot rosier than you might expect.
Plammiman
Newbie
November 01, 2026, 04:51:18 PM »
Hi all
As today was a bit dreary I decided to go into the loom as I had easy access. I found a manufacturing joint for the black wires which had a dry joint. See picture. I could wiggle it and get the rear brake light to work. Nice to have a confirmation of the fault. I desoldered the joint, cleaned up and resoldered. One section of one of the wires hadn’t been tinned, hence the problem. I checked the green and yellow wire brake light joint while I was there but it was good. Whole job no more than half an hour. However I do have to re wrap the loom to complete. I have attached a photo for everyone’s reference as it shows where you can find these joints.
Reply #10 on:
November 02, 2026, 04:49:08 AM »
That works just takes a lot of time!
