Author Topic: CB750 F2 wet sumping  (Read 328 times)
Offline archmill
« on: October 31, 2026, 07:38:50 PM »
Looks like i've fixed the wet sumping with an oil pump kit from CMSNL. Noticed that the pressure relief valve spring was about 10mm longer in the kit than the old spring. The oil pressure has went from 60 psi to 80 psi (85 on a rev) and that seems a bit high to me. Engine running for about 10 mins and its still at 80. Any damage being done ?
As a side note, while the oil pump was out, I rigged up a vacuum pump (from a brake bleeding kit) on the end of the oil leak stopper chamber and with the idea on Newtons 3rd law of motion (every action has an equal and opposite reaction, checked out the pressures required to open the oil leak valve :-
with the old spring fitted - 1 inHg (that's 1/2 PSI and the gauge hardly moved)
with the new spring fitted - 2 inHg (1 PSI)
New spring fitted, valve fully open - 4 inHg (2PSI)
Although I have to admit I don't think Newton had a Honda (his loss)
Re: CB750 F2 wet sumping
« Reply #1 on: November 02, 2026, 09:35:59 AM »
Interesting that there's quite a difference in spring length (preload when installed) which appears to give unwanted lift in control pressure.
It's obviously not the spring that "makes " the pressure, but the system of oil distribution and pump effectiveness.  The relief is there ultimately to protect the oil pump drive against hydraulic locking/high pressure.  The risk being failure of drive when used against that pressure above designed operating specifications.
Anything that's been worked on to cause high pressure in the system  ?  Oil present in both sides of the camshaft &  valve cover ? Thinking of the oil flow restriction into head here, one on each side.
 Oil temperature and viscosity need to be quantified in assessment of the higher pressure, but could be normal for cold engine, hence the factory set point of pressure relief being as it is.
I share your concern, would rather use the original spring in this case. Then check the peak pressure with that, if in specifications then no reason to not use it.
Offline archmill
« Reply #2 on: November 02, 2026, 10:11:04 AM »
Thanks K2-K6, am going to put the old spring back in as nothing else in the engine has been worked on, the only work I did was to replace both springs and  the oil leak stopper in the oil pump as the task in hand was to fix the wet sumping. I replaced the pressure relief spring because it was in the kit.
80 - 85 psi is not something I am comfortable with
