Author Topic: Any ideas?? Have you seen this part?  (Read 148 times)
Offline badger_eng
« on: November 05, 2026, 06:28:31 PM »
Started to clean the crankcases halves, barrels, head etc today prior to vapour blasting.
Dropped the sump pan into a washing bowl with a cup full of petrol in, started degreasing it and as I worked my way through the sludge caked into the ribs in the bottom of the sump, I could hear a metallic noise as I brushed away in the petrol / oil mix???
The metallic sound turned out to be this….
Does anyone have any idea what it is??
Thanks in advance
Pete
Current:-
Suzuki GSX-S1000GX+ - 2026
Suzuki GT500A Cafe style - 1976
https://www.kettleclinic.co.uk/kcforum/viewtopic.php?t=14273
Honda CB550K - 1977 (Winter 2026/27 project)
Offline Athame57
Re: Any ideas?? Have you seen this part?
« Reply #1 on: November 05, 2026, 07:00:19 PM »
Hi
I'm no CB550 man myself, but a hunch had me explore the diagram here on the cmsl site. Looking at the shape could it have anything to with this? (arrowed)
1978 CB400F2 named Elen.
Offline badger_eng
« Reply #2 on: November 05, 2026, 07:09:35 PM »
Thanks for the reply…. I’ve been doing the same. Looking through the exploded diagrams and parts lists for all the internal (to the engine) items.
The item you highlight is the cam chain adjuster and tbh, when I removed the assembly it looked like all parts were present. However, this is also my first CB550 strip so although the cam chain assembly looked complete and is now bagged up and stored, I’ll revisit it tomorrow and see if it could be part of it.
After buying the bike, I’ve only ran it in the garage to work through the PO’s long standing carb problems and then again to fit another set that Ian supplied me with.
I have done no maintenance, just straight into the stripdown process so if it is from that area, it could have been there for a long time.
I can see no shear or fatigue points on the offending item so it could be a loose item from that area…. or not 🤔
Like I said, I’ll take a look at the cam tensioner assy tomorrow and see if it could be a stray part.
Thanks again 👍
Current:-
« Reply #3 on: November 05, 2026, 07:24:51 PM »
Belongs on the cam chain tensioner as pointed out by George
« Last Edit: November 05, 2026, 07:27:04 PM by Nurse Julie »
Offline Athame57
« Reply #4 on: November 05, 2026, 07:31:06 PM »
Thanks again 👍
This looks more convincing!  ;)
Offline badger_eng
« Reply #5 on: November 05, 2026, 07:47:58 PM »
Forget Nurse Julie....
Instant promotion to Sister!!
I wonder how long its been laid in that sludge :-)
Thanks Julie / George, much appreciated.
Pete
Current:-
« Reply #6 on: November 05, 2026, 08:07:42 PM »
May not be from the tensioner you have but from a previous broken one, that sort of thing happens when the screwdriver slot is used to tension the chain
Offline badger_eng
« Reply #7 on: November 05, 2026, 09:19:29 PM »
Good point. It may be that I have a spare now :-)
Current:-
« Reply #8 on: Today at 04:04:47 AM »
Except if that falls out the tensioner is broken
Offline badger_eng
« Reply #9 on: Today at 07:50:52 AM »
I shall feedback what I find later today….
Current:-
