Author Topic: Oil filter housing O Ring keeps blowing out  (Read 651 times)
Re: Oil filter housing O Ring keeps blowing out
« Reply #15 on: November 10, 2026, 08:12:50 PM »
One possibility, is the outlet from pressure relief valve blocked? I ha rebuilt lots of pumps but never checked where the oil goes if relief opens!
Presumably when the pump is removed you can see the oil path hole on the engine casing face?
Offline Johny Boy
« Reply #16 on: November 10, 2026, 08:19:09 PM »
Funny, I've just been sitting here wondering about the same thing.
I'll strip it tomorrow and find out
CB550 (85% there)
New BSA Goldstar (my daily)
MV Agusta F4 750 Senna (Front room love affair)
BSA bantam (my constant pain in the arse)
« Reply #17 on: November 10, 2026, 09:08:47 PM »
Should be easy enough to squirt some oil through with an oil can to test the gallery.
« Reply #18 on: November 10, 2026, 09:22:20 PM »
Being honest its one of those things you dont look for till you have a problem and i have not seen that problem
Online badger_eng
« Reply #19 on: November 10, 2026, 09:39:58 PM »
The picture that’s been posted shows a lovely finish to the cases. Have they been vapour blasted??
Only wondering as if they were not rinsed out thoroughly by the blasters afterwards, it’s possible that some of the glass beads have solidified in an oil way??
If they’ve not been vapour blasted.,,,,, just ignore me 😬
Current:-
Suzuki GSX-S1000GX+ - 2026
Suzuki GT500A Cafe style - 1976
https://www.kettleclinic.co.uk/kcforum/viewtopic.php?t=14273
Honda CB550K - 1977 (Winter 2026/27 project)
Offline Johny Boy
« Reply #20 on: November 10, 2026, 09:51:51 PM »
Hi badger, yes they have been vapour blasted and they do look brand new, well worth the money if doing a full rebuild.
You raise a good point, I did give them an extra wash but now really wishing I had blasted some 6 bar air down every hole, which I can't guarantee I did.
If I can't find the issue with the relief valve, a full strip and clean might be necessary.
From what I read the relief valve should open about 60 psi, roughly 4 bar so I am going to investigate and then see if I can get it to move with some air pressure.
CB550 (85% there)
Offline Johny Boy
« Reply #21 on: November 10, 2026, 09:55:14 PM »
You can see the overall look of the vapour blasting here [ Guests cannot view attachments ]
CB550 (85% there)
Online badger_eng
« Reply #22 on: November 10, 2026, 10:09:41 PM »
Mmmmmnnn shiny! I love shiny 😬
I’ve had 3 engines VB’d previously and 2 were well washed down. One was not and it took a while for me to get it bead free.
My CB550 engine is getting done next week now it’s fully stripped. I’m ultra careful now with the oil ways and threaded holes after my one bad experience. I still get them blasted even if I’m painting / polishing as the finish is great to work with.
Hopefully you’ll find the issue quickly and cheaply.
Current:-
Online Oddjob
« Reply #23 on: November 10, 2026, 11:51:12 PM »
Did you remove the oil gallery plugs? One under the points cover, simple 14mm nut affair, the other sits under the rotor cover and is a press in fit. You can pull it out but it does tend to ruin it a bit. Best way is to remove the points end plug, get a long piece of wooden dowel and knock the rotor end out from the back with the dowel. No damage that way. Once both are out you can look down the gallery and see if it’s clear. The oil filer empties into this gallery so check the gallery that joins the two isn’t blocked. That would blow the housing apart if it was.
« Reply #24 on: November 11, 2026, 09:24:16 AM »
I'm of the same view as Bryan, in that the pressure relief valve should prevent the risk at oil filter. That's if there were blocking further along distribution.
That doesn't mean there's no impairment within the system for flow, but primarily the relief would appear obstructed in some way.
Looks like there's enough questionmark over absolute cleanliness from blasting operation to need stripping anyway though.
Difficult to have confidence longer term if all passageways haven't been checked and accounted for to run competently.
« Reply #25 on: November 11, 2026, 09:38:57 AM »
If you didn't fully check and clean the oil ways then I agree a strip down is needed.
I don't know the particle size they use, you don't want any of it reaching your crank bearings etc.
Many years ago I had a major issue with a Mini engine after having the block sand blasted, for that reason I have avoided  bike engines being blasted by anything.
Offline Johny Boy
« Reply #26 on: November 11, 2026, 11:45:18 AM »
Many thanks to everyone who has contributed to this thread.
The knowledge here is amazing and offered so freely.
I have decided it needs a full strip, clean and rebuild.
I guess you live and learn
CB550 (85% there)
Offline martin_uk
« Reply #27 on: November 11, 2026, 12:02:21 PM »
Me too, heard so many horror stories
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Online badger_eng
« Reply #28 on: November 11, 2026, 12:06:35 PM »
No horror stories with Vapour Blasting in my experiences.
Like anything you do, do it right.
Clean / check any oil ways, run a tap thru the threads…. then do it again.
Costs nothing but time
Current:-
« Reply #29 on: November 11, 2026, 01:37:15 PM »
Here's the correct way round of you want to check.
