Author Topic: Hagon fork springs.  (Read 443 times)
Offline WestMids-CB
Hagon fork springs.
« on: November 14, 2026, 11:59:35 AM »
Just curious if anyone has fitted the Hagon progressive springs to the 750? If so, was it a good improvement, better feel and handling?
Much appreciated.
Re: Hagon fork springs.
« Reply #1 on: November 16, 2026, 01:21:41 PM »
I feel you need more defined "something" you're trying to respond to in using them.
Ordinarily, if you're light weight, in comparison to bike, or generally overall less total mass than could be typical of the bike in design intention.  In which case, it could improve suspension comfort, but less the handling in ultimate terms.
If you're overall bike mass + payload is high, then going tbe other way with fully stronger spring rate would be typical.
General handling, I'd put a list of requirements first:-
1) Headstock bearing, condition, lubrication, adjustment.
2) Fork stanchion, bushes/play, internals clean and secure.
3) Fork oil, prefer dedicated fork oil product with properties specified to target non-foaming and importantly friction reducing mix to improve stiction characteristics and hence response to bumps etc. I use Motul @10 viscosity as good start point (others available) to facilitate above.
4) Swing arm bushes condition and lubrication, prefer CV grease (black molly incorporated) for high load, long lasting, very low friction under load. Bonze replacement have usually been available from Julie's shop for these bikes.
5) Tyres, good profile, not squared off rear, checked for alignment and concentric mounting.
6) Engine mounts of correct bolts and torqued securely, affecting chassis integrity.
7) Basic alignment check of wheels, along with how the rear is set in chain adjustment setting.
8 ) Properly cleaned and set idle characteristics, with patchy response and iffy cylinder running playing significant role in corner entry  characteristics. There's quite strong engine braking and linearity in gear changes that influence how it feels in refined handling.
All set correctly, then they are much better than contemporary press reports and historical heresay would have you believe.
