Author Topic: Indicator Switch Issue  (Read 523 times)
Offline Neilw
Re: Indicator Switch Issue
« Reply #15 on: Today at 11:00:09 AM »
Isn't there a spring loaded ball bearing that acts as a positive stop?
There is a ball bearing; it sits under the slider. I think there is a spring too, iirc, which applies pressure to the bottom of the slider, so it moves smoothly from one side to the other.
Online TrickyMicky
« Reply #16 on: Today at 01:00:56 PM »
If there are no daytime lights or bulbs fitted is this idea still  valid Micky?
Would your idea lead to a dull glow somewhere else in a light unit?
The mystery of electrics know no bounds.😁
  Good point Ted. I have not found out yet whether it is a UK or USA spec model, but, the fact that it works ok until the switch is moved to its full extent definitely points to a switch problem. Depending on the market, UK/USA, there is the possibilty of current leaking to the dipswitch, or headlamp flasher. If it's a USA model, is the dipped headlamp on all the time? If so, then maybe it's difficult to see if current is being fed to perhaps the main beam circuit. Would definitely go for a replacement switch
Offline Neilw
« Reply #17 on: Today at 01:18:14 PM »
Sorry, It's a UK bike. 1978 F2.  I think a new switch may be the way to go, but since I can use it, I'll take my time finding one, as I'd like to keep the existing casing and replace the internals.
« Last Edit: Today at 01:20:17 PM by Neilw »
Online TrickyMicky
« Reply #18 on: Today at 01:52:06 PM »
Is this it??????
