Author Topic: Indicator Switch Issue  (Read 899 times)
Re: Indicator Switch Issue
« Reply #30 on: November 25, 2026, 07:04:25 PM »
The 500 switch isn’t the same as the 400 Ted. There are more wires in the 550 switch than the 500 one. No high/ low switch for instance. It had the function to just push a little on the indicator switch so you just got a few flashes but it didn’t stick in position so as soon as you let go it cancelled itself. Saved you having to remember to turn them off.
